1600W Titanium, Platinum & Gold Super Flower power supplies now available!
22 Aug 2010
Being first to market, Overclockers UK's have the first 1600W power supplies listed from the multi-award winning Super Flower, featuring the latest "Titanium" and "Platinum" Rated efficiency, bringing a new standard to power supplies.
Super Flower, one of the worlds leading power supply manufacturers have added the Leadex 1600W to their range, offering up to 94% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage with multiple certifications in the market..
The Super Flower Leadex 1600W Power Supply features a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The 1600W comes in the Titanium, Platinum and Gold certification. As always with the Leadex models, the power supplies are fully modular for easy cable management, and so you don't use more cables than you need to.
Super Flower power supplies are perfect for gamers and enthusiasts and now with the higher wattage seamlessly powering high performance graphics cards in SLI / CrossFire without breaking a sweat.
Proven by multiple awards, Super Flower is the choice of power supply for all users. All power supplies come with a 5 Year warranty
SuperFlower Leadex Titanium 1600W Fully Modular "80 Plus Titanium" Power Supply - Black @ £299.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed the Leadex Titanium range, with full 80 Plus Titanium Certification, offering up to 94% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest Titanium rated PSU's on the market.
All Leadex Titanium Power Supplies feature a fully modular design, 140mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Titanium series are an uncompromising masterclass of design and functionality and should be the first choice for any gaming system that needs one of the most efficient power supplies on the market!
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Titanium Certified, 92% 94% 90% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 220 mm (W x H x D)
- Fan: 140 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 94% (115V), 80 Plus Titanium certificate
- Active PFC
- 3.3V: 24 A
- + 5V: 24 A
- + 3.3V & + 5V combined: 120 W
- + 12V: 1,599.6 W / 133.3 A
- -12V: 6 W / 0.5 A
- + 5VSB: 15 W / 3.0 A
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-1600F14HT
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-Pin-PCIe
- 14 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Only £299.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1600W Fully Modular "80 Plus Platinum" Power Supply - Black @ £259.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Platinum to their range, offering up to 92% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Platinum rated PSU's on the market.
All Leadex Platinum Power Supplies feature a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
Specifications
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Form Factor: ATX12V 2.2 / EPS12V 2.92
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- + 12V: 1999.2 W / 166.6 A
- -12V: 6 W / 0.5 A
- Partcode: SF-2000F14HP
Connectors
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Only £259.99 inc VAT.
ORDER NOW
SuperFlower Leadex Gold 1600W Fully Modular "80 Plus Gold" Power Supply - Black @ £224.99 inc VAT
nonl2br
SuperFlower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Gold to their range, offering up to 90% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Gold rated PSU's on the market.
The SuperFlower Leadex Gold 1600W Power Supply features a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features
- 80 PLUS ® Gold Certified, 87% 90% 87% Efficiency At 20% 50% 100% Rated Load
Specifications
- Efficiency: max. 90% (115V), 80 Plus Gold certificate
- Active PFC
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- -12V: 6 W / 0.5 A
Connectors
- 1 x 8-Pin EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Only £224.99 inc VAT.
ORDER NOW
Bought my CM 1000w Silent Gold for £90 in B-Grade from this very store, absolute bargain and served me well this last 2-3 years.
These are absolute quality though, and if I ever go 295x2 Crossfire then I'll be plumping for one of these babies :cool:
£300 for a power supply? wow. Perhaps I'm getting old in the tooth but prices only ever seem to go up.
First 1600W Titanium power supply, remember you pay for quality. The Super Flower have been given some of the highest awards for quality, now that's something you want to hear especially with PSU'S :-)
I would rather see better sf in 500-700 range, I ordered 550W and it have 12cm fan, short gpu cables and the sli option is a joke, they make good psu*just not the one OCUK offer
Such a beast of a PSU!
I hope Superflower gives the option to turn off the lights on their PSUs, in the near future.
Spend a lot on a PSU and you may get to run a 970 card whine free, I read that lots.. but only on here!
Still coil whine reduction tech on cards sold here are whining!, still spend a few hundred £'s more to try and help!
Not impressed, address an issue rather than marketing please!
Super flower once again making corsairs top line look poor value in every aspect, the 1600w titanium is not only higher rated then the 1500i, it's also a decent margin cheaper.
Are these all identical units, which have been individually tested, and categorised depending on their individual efficiencies? :p
Also the Gold and Titanium ones apparently have 1600W on the 12V, but the Platinum has 2000W on the 12V.
Accidental leak..? ;)
I agree with a lot of that. But then I already had a Superflower 1000w Platinum and got coil whine on two apparent coil whine free Infinity cards, so the whole PSU argument is a load of tosh, unless of course the PSU is actually faulty.
We would never recommend these for any single card, these are PSU's for extreme overclockers or those building an absolute beast of a PC with several GPU's.
We recommend quality PSU's to help try and reduce whine, its being proven to help in such cases and such power supplies start from £49.99, no one here is recommending anyone to spend hundreds, might want to get your facts right. :)
It's only a small minotity that will be buying these as it's way too much power for a normal pc. What we need on here are more quality small capacity (350-500w) psu's, especially modular ones, not monster's like these. What about the Golden Green modular series as well?
Personally if I was doing anything that needed that much power, I would just save money by buying a pair of 850W PSU's, linking them up and distributing my components accordingly.
Awesome product though, the GTX-Titan of the PSU market :D
making smaller power supply then 500w
will not reduce the price significantly
there is no reason to make a 350w platinum psu
no real point in making a product that limits its market exposure for 5 pounds cheaper
and platinum versus silver at 350w has a very small difference in power draw from the wall
besides achieving high efficiency at 20% load for high efficiency qualification
at 350w is very hard
if you need a good psu buy a good psu
nobody will make a 350w modular platinum
at 1600w nobody will need that number
but there is a demand and the need to make the best so here it is
