Thanks guys
I think the novelty of having the roof down will wear away a bit but not entirely. That exhaust note with the roof down I tell you will never ever get old!
I know we've had some poor weather and yes indeed dirt shows up much easier than on the Titan Silver I had before. Even light stone chips are more visible as white specs - Sacrifices have to be made though I guess. I've seen those clear film wraps you can have applied on all panels, one guy did it to a custom 330Ci in the USA. No idea on costs or anything on them though but it's certainly an option if the dirt and grit showing up does end up being a right pain. At least it won't be harming the paintwork.
It is Carbon Black but it's more of a very dark midnight blue. I wondered why it was called as such but then it hit me, Carbon Paper is often a really dark bluey colour
I will most likely keep the wheels kona, as you say they are unique to the E46 and this new finish is really sweet. I really like CSL wheels but as you say, too many reps about.
The OBC was indeed showing 31.2MPG on a motorway run - It is a great engine and as bizarre as it may sound, economical for the performance on offer and the weight it's pushing. Local driving nets me 22-25MPG on average with bursts of excitement. I know some have said they've seen mid teens but they must have been flooring it everywhere!
Your not trying hard enough.
Yep can match your motorway run, but I typically average 17-20mpg which involves no motorways.
Also a tip if your car consumes any oil at all, mine was using 1/2 litre every 1000 miles, I changed out the air oil separator, a £20 part and 10 minutes to change, my car now uses no oil.![]()
Already have the correct CSL tyre sizes so all good, I will keep these 19s though I think having thought about it some more. Thanks for the tips above though, the air oil separator sounds interesting, will keep an eye on oil consumption.
Btw I already have Euro tips. I'm just having a ballache of a time getting the stock tips off. Those pop rivets are on sodding tight. I can't even chisel them off. Someone recommended using a file to get them off but I can't see how could use a file correctly in that space? Probably a much easier idea to just take the whole backbox off and do it that way.
A job for another day![]()
Looks really nice. However £13k is getting towards the pricey side and would have definitely wanted the navigation unit and heated seats to justify paying near top whack.
and smg.
jk mrk m8. Lovely looking car.
Nice car, the guy who sold me his 330ci had just upgraded to one of these. Perhaps a path I will take come new car time
That Andrive headunit looks great too. What was the cost of it, I can't seem to find the product on their webpage?
Absolutely lovely.
Black looks great when freshly waxed, but you'll soon hate how quickly it shows any sort of dirt. Especially this time of year.
Even those summer specs of dust show instantly.
Would this be applicable for a e46 2003 330ci? I go through a litre in 600 miles.
What don't I like?
- I don't like the weather-depending creak introduced by the softtop rubber seals rubbing against the windscreen frame. There is only 1 creak but it is consistent and only over rougher roads. I will spend some time cleaning this area until it's gone but it's low priority and quickly tuned out with the right foot![]()
