and smg.
jk mrk m8. Lovely looking car.
Yeh it does look seriously well looked after.
On that topic, I completely see why he would get the manual, as I'm looking for one also. SMG is OK but the potential to give £2000 bills with no warning whatsoever and without you being able to move the car is just too great. This wouldn't be so much of an issue, but with the backdrop of a car that costs £700 for a set of tyres, up to £800 for a service, headgasket problems, clutch changes and subframe issues ON TOP of your regular normal car issues, you start wondering if you really need yet another thing that can drop a bill of such magnitude. I don't care what people say about how the internet has exaggerated the problem, the bottom line is that a 11 year old car with 70-100k miles will have a failing SMG pump at some point. It might be tomorrow, it might be in a year or two, but it will happen.
Not to mention you have the salmon relay problem which although not expensive or time consuming, could be annoying. And you can often get clutch slur even with half the clutch still there. Then there is the low speed clunky gear changes.
For day to day driving I think a manual would just be better. For that time when its dry, the road is clear and you want to give it some, SMG would be great. Every other time, manual would be best.
