No problem.
Cool
Updated line up below:
Monday 7PM CE (Normal Mode - Crota checkpoint) - PS4
- OweO - 32 Hunter "Moody"
- Piphal - 31 Titan
- FaceBaker - 31 Titan
- MachM - MachM82 - 31 Titan
- PaulM - Turbo_Nutter - 31 Warlock/Hunter
- ZeroSight - 31 Hunter
Does anyone else want to join in taking down Crota on normal (Crota checkpoint)?
We can probably 5 man it but the more DPS the better![]()
I have 2 characters 32 and a 30 (nearly 31 has full CE raid gear so potential for 32).
Done VOG on HM x 2
Done CE on NM x 2
Done CE on HM up until sunsinger (exotic drop)
Anyone doing HM on CE tonight? Would like to run it once fully before the reset.
I can join on normal with my lv 31 titan
I just need lamps on hard and crota on hard on my hunter. I will be doing normal @ 19:00 for crota but if this goes well should be free from 20:00ish. Happy to join at sunsinger or fresh run as it doesn't take too long
CE Hard Mode 8PM Monday (today)
1. PsychoSonny
2. FaceBaker
3.
4.
5.
6.
If we don't get enough I can LFG the rest (the new site I use tends to have really good players on it). Managed VOG HM in record time the other day. One guy held mid on his own before Atheon checkpoint.
Would you mind taking a LV31 Titan? I have the gear, but not the Glimmer for 32. I have the CP for Crota as well.
Tuesday PS4 Crota's End 7pm GMT.
1) middgen 31 hunter
2) OweO - 32
3) Tibbz2 - _Sgt_Angle 30
4) BF-Bert - DavieM66
5)
6)
Just updating time on this run. I will be around for Nightfalls before and after....
1. PsychoSonny - 32
2. FaceBaker - 32
3. AStaley - 31
4.
5.
6.
Yeah sure, I have no idea how much difference it makes in CE. I think it should be do-able if you have decent weapons maxxed out and everyone else is 32. I have noticed it depends a lot on the player as well as their level. I would rather have a really good player at 31 than a crap one at 32. But it does mean you do like 33-50% less damage than if you were 1 level higher.
Do you have all the radiant shards? If it's just glimmer you need then google "glimmer farm" and look at recent videos. I think you can get 12,000 glimmer per hour on the exclusion zone farm with resupply codes. It's boring but if you need glimmer needs must.
Having one or two 31s is definitely fine for CE HM. We're going to do it tonight with a 31 and a 30!
Happy to just do from sunsinger (do you mean deathsinger?). Middle or each side with titan bubble strat is fine. Can sacrifice one to distract boomer from behind rock as well if you want. See you at 20:00 (normal HM completion permitting.)
