***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Tonight's Vape
Ok guys,
Recommend me a full size tank.
Nautilus, Protank II or Protank III or something else?
What mod have you got? as the subtank mini (like V_R says) is the best at the moment... but your mod may not fire it.
Ah! Is it the high PG? Do I need to get a lower one?
It could be that, or it could be that its cheap rubbish. A PG intolerance wouldn't surprise me. Would be good to know what it was tbh. :)
Tonight's VapeWhat mod have you got? as the subtank mini (like V_R says) is the best at the moment... but your mod may not fire it.
Ah yeah good point, he's got an iTaste IIRC... Ok, not the Subtank. :D
Also todays reports:
the plus side.
Japanese cotton I got a delivery of today, jesus Christ. its so much better than johnsons cotton pads that you use for wiping a babys arse :p hahaha!
I didn't think it would make much different as cotton is cotton, but Christ does it!!
22g kanthal, got a 0.2ohm 7 wrap 3mm drill bit, build, and pwoarh, it hits like a son of a.
Nice and warm! but..
On the downside, im out of 3mg vg juice. Only got 6-8mg 80% pg juices. my throat is killing me, got dry lips already. hate pg. if my vg juice doesn't arrive tomorrow, argh!
You might want to try that KF 4 again.. It should wick better with jap cotton and reduce the dry hits.
Sadly the zero is a clone slinky...:(
The authentic are:
Sigelei 100w plus
istick 20
istick 30
egrip
vaporflask 2.1
svb dna 30
kamry k100 e pipe
and the chip in the Cloupor Mini is a dna40 chip, c/f modes ;)
I will do :) it's just a little bit broken at the moment, I tried drilling out the centre post thing that provides the air flow. The centre shaft thing Dno what the actual name of it is, but yeah tried drilling it out cause damn did it feel restrictive after using drippers, and yeah I broke it haha drill bit was a bit wide but iv got one of them ss kit bored out centre posts on the way from good old fast tech anyway.
Oh also got a orchid on the way to play with. :)
Stainless steel is horrible to drill at the best of times. Whenever I've enlarged holes I've used diamond ball bits from my dremel. It takes a while but the hole you get after looks clean and you don't need to clamp the atty or worry about the bit grabbing. You just have to make sure the bit is kept cool with some light machine oil like 3 in 1 or sewing machine oil.
https://www.etsy.com/uk/listing/214...ghoeqLuO_mFpu1i9-_DUjleNoR7uAYWrALRoC36_w_wcB
aye I know, well I did drill it out pretty decent actually, but I dropped it and it was pretty weak was the centre post after drilling it out, and I stood on it and snapped it :p
I wonder if the density difference between VG and PG would allow dropping it in water to separate. Might be able to see the difference.
I'm not sure what you mean. If it was without flavouring you can weight it to see how much VG / PG there is. Most of the time it is fairly easy to find out the ratio just by asking. It is common knowledge the ratio of most juice. Like almost all Chinese juice is 80/20 or 70/30 PG/VG. High VG juice is normally being promoted as such and will tell you how much VG it has.
Have you thought that the air flow on a KF is not meant to be that open by design? lol Else there be no reason to have different dripper nor RTAs?
If you want airflow; the lemo drop is massive, I struggle with it at times.
It would be (or should be) difficult to separate without a stabilising substances as they should be mixed in very well, hence all the shaking and steeping that we do. lol.. you can now get 100% VG ejuice as there's VG flavoring and nicotine. :) What I tend to do if I have ejuice that is nasty beyond steeping is mix it with menthol. Most of my juices are at least 50/50 .
I got out carded yesterday and got all excited thinking I had more vapemail. It was my new computer meh :/
Lol I assumed a knock off Chinese product wouldn't have the ratios stated on it. Was hoping there was an easy way to separate it to find out.
Status
