Thought Id just say I was testing out droid4x which is an android emulator(think its basically a virtual box vm). Its pretty damm good easy to setup and most things seem to work. Tried dead trigger expecting a slideshow and it was just about playable and then installed plants vs zombies 2 (only game I want from android) and it works great no issues at all. Comes with play store too would recommend if there are a few games/apps you want from android it does take a few minutes to boot though.
I wonder if Cartoon HD would work full screen with this.
a lot of these tablets can only work at 19MB/s (or stable even if other options exist) some have the options in the BIOS for higher speeds (not normally enabled by default) but on most of the cheaper variants the options aren't exposed to the end user even in the BIOS. If you get one which is setup for higher speeds or can get it working stable you can get 70MB/s with a decent card (SDCX10) never mind UHS-2+.
