Unigine Heaven 4 benchmark
5930k @ 4.4 ghz
2 x 980 Srix SLI 1392/3900
Thinking I could probably push the cards a bit further as temps top out at 75c.
EDIT: picture resize
And on the scoreboard.:)
For the life of me I could not get a screenshot over the coble stones to work so hope this counts
i7 4790K@stock
Palit GTX980 Jetstream Core clock 1503, memory at 4000Mhz.
Unfortunately we need the screenshot over the cobbles.
When you press F12 the pics are stored here
You will need a free third party app to open the *.tga files.:)
Looks like I need to overclock my CPU to bump up the score but I only have a stock cooler :(
When I ordered my bundle from OCUK, I opted for the Broken ECU as it fitted my case being 150mm.
My CPU has never hit more than 72c after a few hours running Heaven.
However I do have 2 Noiseblocker fans in my case now. However my temps have dropped somewhat since I replaced my 970.
Cpu @ 4.0ghz
all on stock volts . dont know where to start on messing with volts . would like to overclock cpu further .
why does the bench say im at stock cpu speeds when im actually on 4ghz ?
cant get any higher on graphics unless i up the voltage and never done it before . i had memory at 4002mhz (+500 on the mem) until half way round the benchmark then its crashes .
