*** Destiny Raid & PvP discussion thread ***
Hi guys any PS4 normal mode runs over the weekend I can jump in on? Lvl 31 Hunter. Need the raid legs to drop. I have the other 3 pieces but no exotic legs so 32 is still impossible. And I need the shards and Black Hammer :-)
I have one more character to go through CE and am not sure on my plans for the weekend yet so just putting it out there to see if we have enough for a group tonight? I'll say 8pm but can do earlier or later depending on the consensus.
crota's end X1
1. WriteThatD0wn titan 32
2. KWJay Hunter 31
3. WardyP
4. thoseion - Hunter 32
5.
6.
I'll put my name down but I only really have an hour and a half (8:30-10), so if we can get another couple 32s to help out, that'd be great! A Warlock or two would be nice for the Bridge. :)
If it's a hard run we're doing then I'll be bringing my warlock, he's only 31 though but fairly well kitted out.
cool - It would be preferable to get another couple of 32's with a bit of luck if we started promptly then we could get it done in time, let see if we get another couple :)
Sorted - See you all later. I think I also have one more weekly to do so if anyone is around before and needs it then let me know. Not sure I really need the coins though given Xur's stock.
crota's end X1 20:30
2. KWJay Hunter 31
3. WardyP
5. Ehhh Mazin hunter
6. thedeadparrot84 warlock 32
2. KWJay Hunter 31
3. WardyP
Great! If KWJay is also a Warlock, it should be a pretty straightforward run. I'm assuming this is HM by the way? Wardy, what character were you planning on taking?
Sweet! I'll def bring the warlock with a bit of Light Beyond Nemesis, Red Death, IB/Murmur and HoC I think. Unless anyone has any better suggestions on load out...
Nope that will serve you well although you probably only need red death for crota so if you have a more favourite primary use that for the earlier bits
Got a 31 hunter and titan so which ever is needed as I need to run both, only problem is my titan doesn't have any health regen unless I bring my suros from my hunter.
