Implement a system that makes them die (combat logging). It'll stop overnight.
So basically, they just really need to implement a combat logging system and your golden?
I upgraded to the Cobra as recommended, but it just might just be me doing something wrong, but why cant i upgrade the FSD to allow for longer jumps?
No matter what one i go for is brings the LADEN down hugely!
So what jump range does it supposedly give you for a Class 4 B FSD drive ?
You also want want to look at upgrading other items like basic scanner, life support to class 3 or 4 D - these are the lightweight versions of components that will reduce your mass.
weapon systems should be disabled once entering a station, don't know why they have not implemented this.
Weapon systems need to be disabled at 10k out. Internal will do nothing but force them to hang just outside. If they want the person they need to find there wake and interdict them.
Change sensors, life support and and thrusters to "D" rated, to get the max range, to get even more range - upgrade the FSD, but you'll need more money![]()
Do you have enough spare power to run the better FSD? Upgrade your Power Plant to a 4A, and then the FSD to a 4A as well. That should get you to around 20LY fully laden (depending on what else you have equipped).
As mentioned, replaced all the class E stuff with class D as it's lighter and will help increase your range. Avoid the class B stuff as it's super heavy compared to everything else.
4C FSD Mass: 10.0
4B FSD Mass: 16.0
4A FSD Mass: 10.0
Now the server has "combat logged"!
Have just been dumped mid-flight-shift to login screen and can't reconnect.
Edit: Now I get "unable to retrieve Commander data from the server"
Looking good for the weekend then!!![]()
