AMD freesync coming soon, no extra costs.... shocker
Clipping the image is the wrong way to do it, that isnt giving you a wider field of view it is just cropping the top and bottom off, its called vert-, what you want is hor+
Perhaps the wrong words to use. Hang on mate let me just throw something in photoshop to illustrate what i mean.
Hang on a minute....
Has something happened recently? Why is everyone being so nice and civil to one another?
Everyones trying to set an example so that ukraine and russia will take note. If there can be harmony in the gpu forum of ocuk, theres hope for a myriad of other conflicts. Peace out man.:D
Lol tone, it wouldn't be the same without you :D
Setter, I hope you're not comparing our resident amd fans with the red army :o
Sorry about this, stitching images together in a rush doesn't work, especially given that the main image is a 1800P while the other at 1080P.
I can't be #### to spend to long on it but you get the picture, clipping was defiantly wrong on my part.
For a true panoramic view you would use a wider angle render, so that you are filling in the sides with more view rather than cutting off the top and bottom to fit the image.
If this is 1920x1080P Its not, (its 3200x1800 but ignore that)
Then this rather poor illustration is 2560x1080P, what you are supposed to see on the sides is the missing parts of the view you get at 1920x1080P
To get it back to 1920x1080P you would clip the sides of the 2560x1080P render
Thanks for bringing a smile to my face this evening mate. :p
You dont need to do anything in photoshop, look up vert - and hor + and itll be clear which uses clipping which is the quick dirty and low fov way of doing it
Your attempt in photoshop just doesnt make any sense as you arent showing a 21:9 image at all, nor clipping
I take it then everyone has lost interest in the debate?
Oh well, it was good while it lasted
Yeah, clipping was deffo the wrong word, but you're right with that illustration, it's all about adding to the left and right sides, losing nothing from a 16:9 image.
For some stuff in a game (Say 16:9 FMV's) then cropping and zooming them on a 21:9 screen would be better to me.
