Linx 10.1 inch Windows 8 Tablet - Any good?
Just wanted to stick my oar in and say I picked a Linx8 from Sainsbury's this week. Actually went in for a well priced 10 but they were out of stock so I paid more than I'd like for an 8.
It's intended as an iPad replacement for my mother, because supporting her remotely hasn't proved as simple as I hoped. Remote control of this, via something like Teamviewer, is the intention, but so far that's proving to require a little more intervention from my easily confused mother than I anticipated (ideally I'd be able to wake it up remotely without any intervention). I'm sure I'll get that sorted eventually, but in the mean time it's been a much more pleasant experience than I anticipated at this price point.
Battery life could be better, and Win8 is always a great advert for proper laptops, but it's a useful size and slick in use... as long as you avoid Chrome as a browser. Shame, but nothing's perfect.
Given that the latest OS update appears to have turned my Nexus7 into Nexus7secondstodoanything I may be looking out for another one at some point. The ecosystem may be poor, but I've never been impressed by the brave new appy world... so much junk, so little point. And there is, undoubtedly, something rather satisfying about running full Windows applications on such a small device... whether that makes sense or not. :-)
my 10 inch seems to have a lose screen, or something similar. when I squeeze the left side in landscape or even press it creaks. anyone else had something similar. anyone know what linx warranty is like?
Does anybody know what the performance of the built in eMMC is? A bet a fast SD card would not be too far off.
I been tested mine with 350MB/s read and 180MB/s write.
Impressed speed for eMMC that is slower than SSD but much faster than laptop old 5400RPM hard disk and my noisy WD Black SATA3 7200RPM hard disk. :)
Yes, I have this too. I'm not too bothered by it and im not sure why it happens.
I wont be claiming on warranty.
Happened to me too but hold left side bottom and top corners, squeezed it didn't creaked, just the centre creaked. Also happened to my sister Linx 10 too. Seemed affected all Linx 10 tablets so I not concerned about it as long it not broke.
Which device is that? the sub 10" ones I've had access to don't get even close to those speeds, the 10" ones vary a lot depending on what flavour of NAND is on them.
My screen is starting to scratch a bit now and I am pondering replacing the screen protector that it was delivered with. I have read a few reports of removing it can be a bit messy, anyone done it?
Just got mine out and gave it a squeeze (oo-er, missus).
Not even a croak, let alone a creak. I bought mine quite early (End of November) so I wonder if they changed manufacturing process to meet demand at some point.
Just swapped my 8 for a 10 .. well worth the extra.
What kind of gaming are these things capable of? Anything worth playing on Steam?
Thanks!
Thanks!
I play quite a few platformers like castle crushers on mine. They can play portal 2/HL 2 relatively well too. Its really hit n miss to what works well depending on how you want to control it and how well the engine is made.
Can you change the onscreen keyboard? I really dont like it (after using SwiftKey for so long on android, I should add). It is incredibly clunky and unfriendly.
