- 18 Mar 2012
- Eastbourne
That's the one yeah. It doesn't have any wires connected to the PSU that have the same modules as the eps-v12 why meee
Just post a picture.. makes life much easier
Just post a picture.. makes life much easier![]()
I can't but I can say for sure that there are no 8 pin connectors or 4+4 that will math the modules exactly when plugged in.
Can I ask you if there is maybe a connector I can use for this?
Edit I mean an adapter
Here is a picture of the cables that come out of your PSU...the picture is of the Coolermaster Unit you say you have
The CPU plug is the one on the furthest left
Yep that's exactly right but that cpu plug at the left when joined together amount to a pcie connector (as above) but the female connector is an eps 12v
they put out a completly different amount of power and voltage to a different set of pins....the 4+4 on the left is not the same as an 8pin PCIE connector.
If the 4+4 doesnt fit try switching the 2 blocks of 4 and make sure the peg clip is facinf the correct way for the socket, ive done it before where ive tried to plug it in and got frustrated to then discover i had 1 half of the connector facing the wrong way
It's the modules I'm worried about for example in my scenario a little square module is being plugged into a square with 2 rounded corners
Your first picture was removed by admins, upload it to photobucket or something then post it again![]()
