cpu power cable correct?
I can't but I can say for sure that there are no 8 pin connectors or 4+4 that will math the modules exactly when plugged in.
Can I ask you if there is maybe a connector I can use for this?
Edit I mean an adapter
You can buy them, just google it. But personally i wouldn't trust it.
It says on the site that if you do not choose to overclock then you can use the adapter, it uses a 4 pin and turns it into an 8 pin. There is also 4 pin and molex into an 8 pin.
EDIT:
Is it a new PSU? If so return it and get one with enough cables?
YOUR BASKET
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £49.99
they put out a completly different amount of power and voltage to a different set of pins....the 4+4 on the left is not the same as an 8pin PCIE connector.
If the 4+4 doesnt fit try switching the 2 blocks of 4 and make sure the peg clip is facinf the correct way for the socket, ive done it before where ive tried to plug it in and got frustrated to then discover i had 1 half of the connector facing the wrong way
Check the first picture I posted above that's the way I have it
It's the modules I'm worried about for example in my scenario a little square module is being plugged into a square with 2 rounded corners
Your first picture was removed by admins, upload it to photobucket or something then post it again :)
Ok, no pictures necessary, just see below please.
1) I'm using the only wires on the PSU that has CPU wires (all the other ones are being used currently).
My motherboard slot is shaped like this:
My 2*4 pin is shaped like this:
The question is, will my 2*4 (which makes up a pcIe I believe) be compatible with the motherboard slot posted above even though the modules are different?
