***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Managed to get my GVC fix, website is dog slow.
I was camped on his site at about 0845 and all was well. Once 0900 came, though, that was a different kettle of fish altogether. Took about 2 minutes to load each page, and I thought it was going to timeout during checkout! All good in the end.
With VAT and shipping, that is the most expensive 30ml bottle I've bought, but it's worth it! :)
Ah I forgot about that today... :/
Oh well I do still have about 50ml tbh lol.
Edit: just managed to get a 50ml 100% VG 6mg in about 30 seconds. :D
Are you for real? Its the same ****ing link! Must be your end then, it works fine for the rest of the world.. :rolleyes:
EDIT: Yep, even works on my phone.
Hey I don't know why it doesn't work here, maybe a problem with my browser but it doesn't change the fact it doesn't work. Just checked my phone it does work there, must be my end.
If you are losing the will to live perhaps you need more important things in your life to worry about?
:rolleyes:
On a vaping note... just gave myself something else to moan about, I've just ordered from fasttech again, I needed a tank for my microstick so I've grabed a KF mini to test it with.
Any other suggestions of tanks? needs to have a 510 connector and be less than 16mm wide.
TIA
spheroid, best by far IMO.
the kayfun mini is quite long and kind of ruins the point of the microstick. spheroid is a better vape. Not cheap mind, but worth it.
I got one a v2 with a v3 kit on it, I just not sure about the way it stores juice.. mind you I'm using a piece of rolled up japanese cotton rather than the stuff that's recommend. Just not sure if I want to spend the whole of £3 pounds on something that only one of my tanks uses. lol
ffs :D i'll post you a slice if you want
cool... freebies.. lol..
I'm not that tight it's just that I have a major issue receiving anything that's more that a standard letter in the post, living in a set of appartments. Just wasn't sure if it was worth me ordering a bag of it, knowing that I'll be outcards/drive to my brothers/walk to the rain forest locker...
I only got the spheroid as part of a trade.
I shall send a message in trust. :)
Thanks
Is it that Sera filter type stuff? I've tried pets at home and they just looked at me oddly.. lol
But there's one or two fish specialist around me that I might pop into.. Jap Cotton works ok, it holds the juice a bit too well; no flooding thou. :)
:rolleyes:
Look, I'm not trying to be a dick about it, but it was clearly an issue on your end, the fact you kept banging on about it just wound me up.
I can also assure you this is the least of my worries... ;)
Anyway. Moving on....
juwel poly pads
http://www.arkpetsonline.co.uk/juwe...d-p-286.html?gclid=COfX9bqNgsQCFYcSwwodOrwAgA
i cut it to size and try and have it so that it is only one layer thick... overlap the angled edges... you'll see what i mean. holds loads and doesn't leak, wicks great
juwel poly pads
Ah... cool.. I will get some myself if it works well, as I can get it from the rain forest and I can walk to the locker at lunch time.. Saves me getting an authentic KF mini. :)
I have just consided getting an aspire mini nova bvc for the mod but only c9 stock it at the moment.
You will get the VAT back it was a glitch on the site this morning :D
I was going to get a smok M80, the idea of a dual 18650 with temp control (if and when needed) for it's price does sound like a bargin. But loads of people moan about the ramp up time, the button looks to be the same as the m50/m65 with it's possible issues, then angelfire mods posted not to use temperture mode.
Smok has responsed:
Firmware Update Notice for SMOK M80 plus
After we sent out the first batch of M80 plus, some of SMOK valued customers are reporting that
the temperature control function is flawed, the coil takes too long to heat up, there is a 5~7 seconds delay
from the time you hit the fire button to the time the coil starts producing vapor.
Regarding this problem, our enginner confirmed that it's a design flaw, we will update the firmware and
upload the new program online in the next couple of weeks, so customer can download and upgrade it
with the given USB cable by themself.
Thanks for Choosing SMOK product. With your precious feedback, we will try our best to optimize the
firmware and provide you a great user experience.
Too late now; I've already purchased two mods this month and waiting for a third to come back into stock.
Seen a few reviewers all complaining about the SMok and its ramp up time in temp mode, but to be honest, none of their previous mods have done well in reviews, the BT50 did not deliver on power for example, and I don't like the battery fitting in the M series mods, if you need to get your battery out in a hurry your bang out of luck, though this could be said of the Hana's but I modded all my hana boxes to use magnets as I don't like the idea of screws preventing quick battery removal in an emergency.
Status
