Big Bike Thread
Status
Not open for further replies.
1 Oct 2003
Huddersfield
Plastic bush, i dont know the size and wont be able to measure as theres not enough left of it. I found a bush n bearing kit on fleabay for £15 so not the end of the world.
I got a couple of igus bushings (plain bearing) from a local supplier. To be honest if the bushing is gone then the roller bearings and seals may need replacing too. I've just taken mine apart today and the bearing had collapsed. Generally they're very easy to service completely.
5 Nov 2010
Seals? I only got one seal on mine, near the crank thread!
The cruddy sealed bearing is still fine, smooth with no play but in the kit i bought you get a new sealed bearing aswell as the bush so i'll probably do the bearing too.
Status
