** THE GOD OF THUNDER IS HERE! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Meet Raiden:
Avexir Raiden 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (AVD3U24001008G-2RD) @ £299.99 inc VAT
AVEXIR AVD3U24001008G-2RD Raiden Series 16GB Kit (8GB x 2) dual channel 240-pin DDR3 2400MHz 10-12-12-31 DIMM desktop memory module.
Raiden series is, a high performance DDR3 / DDR4 gaming memory modules, using world exclusive patented technology of plasma tubes to mimic lightening effect for gamers who seek true stimulation and real excitement, also proves the product making philosophy of AVEXIR once again: "What we believe is how we behave.
These high quality memory modules are built for your confidence which passed 16 hand picked AIST (Avexir Ic Sorting Technology) processes and 14 memory module functional, burn in, and compatibility tests for Intel chipset 7, 8, and 9 series motherboards. AVEXIR built top level specification of Raiden series by using 10 layers performance optimized design printed circuit board and industrial grade resistors and capacitors. It is also featuring Intel XMP technology, you could easily setup Raiden series memory modules to rated speed with zero hassle factor.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
JEDEC Standard : DDR3-1600K CL11-11-11-28 1.5v
XMP : DDR3-2400 CL10-12-12-31 1.65v
Features:
- Exclusive patented technology of plasma tubes to mimic lightening effect
- 8 layers performance optimized design printed circuit board
- Exquisite packaging
- Support XMP
- Hand picked AIST(AVEXIR IC Sorting Technology)
- Golden Finger Protector
Features:
- Black PCB
- White high performance heatspreaders
- Blue Plasma Strobe lightning effect (See product images)>
- SPD programmed at: JEDEC standard 11-11-11-28 values at 1600MHz.
- CAS Timings: 10-12-12-31
- Dual Channel Kit: (2x8GB)
- 100% tested at 2400MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £299.99 inc VAT.
ORDER NOW
Some special king of sexy there, Makes me want to do a white / blue build just for them sadly though that price :eek:
Yeah price is insane, but hey I guess that is the price you pay for something as unique as these, I know its taken them years to pull it off so the R&D cost have got to be eye watering. :eek:
Here is the 8GB Kit:
Avexir Raiden 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (AVD3U24001004G-2RD) @ £149.99 inc VAT
AVEXIR AVD3U24001004G-2RD Raiden Series 8GB Kit (4GB x 2) dual channel 240-pin DDR3 2400MHz 10-12-12-31 DIMM desktop memory module.
Features:
- Support XMP
Features:
- Black PCB
- Dual Channel Kit: (2x4GB)
- Lifetime Warranty
Only £149.99 inc VAT.
ORDER NOW
pity cant get them for my ddr4 mobo :(
They are working on a DDR4 version but as DDR4 runs at a much lower voltage they need to get around that issue first, believe they have a solution and now it is just a case of turning it into a commercial product like these.
Woop thats what I like to hear
Cool as anything, but you would really need to fill all your ram slots to get the most out of them visually. So that's £300 to £600 for Z97 and £600 - £1200 for X79....
