Hi there
Meet Raiden:
Avexir Raiden 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (AVD3U24001008G-2RD) @ £299.99 inc VAT
AVEXIR AVD3U24001008G-2RD Raiden Series 16GB Kit (8GB x 2) dual channel 240-pin DDR3 2400MHz 10-12-12-31 DIMM desktop memory module.
Raiden series is, a high performance DDR3 / DDR4 gaming memory modules, using world exclusive patented technology of plasma tubes to mimic lightening effect for gamers who seek true stimulation and real excitement, also proves the product making philosophy of AVEXIR once again: "What we believe is how we behave.
These high quality memory modules are built for your confidence which passed 16 hand picked AIST (Avexir Ic Sorting Technology) processes and 14 memory module functional, burn in, and compatibility tests for Intel chipset 7, 8, and 9 series motherboards. AVEXIR built top level specification of Raiden series by using 10 layers performance optimized design printed circuit board and industrial grade resistors and capacitors. It is also featuring Intel XMP technology, you could easily setup Raiden series memory modules to rated speed with zero hassle factor.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
JEDEC Standard : DDR3-1600K CL11-11-11-28 1.5v
XMP : DDR3-2400 CL10-12-12-31 1.65v
Features:
- Exclusive patented technology of plasma tubes to mimic lightening effect
- 8 layers performance optimized design printed circuit board
- Exquisite packaging
- Support XMP
- Hand picked AIST(AVEXIR IC Sorting Technology)
- Golden Finger Protector
Features:
- Black PCB
- White high performance heatspreaders
- Blue Plasma Strobe lightning effect (See product images)>
- SPD programmed at: JEDEC standard 11-11-11-28 values at 1600MHz.
- CAS Timings: 10-12-12-31
- Dual Channel Kit: (2x8GB)
- 100% tested at 2400MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £299.99 inc VAT.
ORDER NOW
