Unigine Heaven 4 benchmark
So Last week I flashed my GPU bios...took me a good few hours to get my p.c back up and running after flashing went bad...
Today, I want to just test out Unigine, and see how the New bios I have will run... and I am shocked....
some things not right here surely??
Running at...
I7 5930k @ 4.4oc
R9 290 Tri-x(3 way)
1175/1500
1080p
1440p
You have no tessellation
Try reinstalling the drivers and running at default.:)
Reinstalled the drivers and run it at default, still seem to have the same problem, however valley is fine when I tested. :mad:
You won't be able to see in Valley if the Tessellation is not right.
Have you used DDU to remove all traces of the old drivers and any settings associated with them.
I5-2500K@4400GHz
Gigabyte Gaming GTX970@1520/1900
Quite happy with this score, not much beats the 2500k at present, Dont think in 12m i will say the same about the gtx970......
2 x 980 Gigabyte G1 Gaming 1562/1951 (one on water, one on air)
4790k @ 4.6 (water)
I5 2500K @ 4.7
GTX 980 EVGA SC 1600/4050
Broke the 2000 barrier on a Single 980 GTX
:D :D :D
