Yeah, the other thing is that normally if you're in a bunch you're pointing or shouting out hazards all the time. If i'm out on my own, i won't do that obviously. So if someone's decided to sit on my wheel and i don't know they're there, then i might swerve suddenly to avoid potholes without any indication etc in a way that i would never do in a bunch.
It's just knowing and trusting the folk you're riding with. You get a feel for how much experience different people have, or if they have a habit of dropping back a bit rather than sitting close to the wheel in front or being a bit erratic etc. And i think as well that it can catch people out a bit when you get a bit of contact in the bunch and not to panic and start wobbling about. It wasn't until i started doing a lot of group riding that i realised how often you end up so close that you're rubbing shoulders, or even bumping handlebars a little sometimes. Or it's quite common to get a hand on your back or shoulder just so someone can let you know they're there if they are passing on the inside or moving position when the bunch has got a bit cramped. It definitely takes a little while to be comfortable with all that stuff going on and stay concentrated on the road and your surroundings.
