anything like that worth doing around london? I'd like to cycle to the start line first ha![]()
might be a good way to get my self out for some rides during summer!
You could do the Compact 50 from Cobham. Twice.
It's 4900ft in 56 miles.
Is your rear wheel true? That can cause creaking and strange noises.
Tried tightening your pedals?
Checked the bolts on your bottle cages?
Checked the little bolt that goes around the bottom of each valve and holds it against the wheel rim?
Bikes are weird - you can be absolutely convinced a noise is coming from one area when it's actually another.
The crank arm pulls out with the whole axle through the middle. You can give it a tap with a rubber mallet or similar on the bit sticking out where you removed the other arm if you need to.
The BB is a sealed bearing unit, you wont be able to get at the bearings.
Other common things which can cause creaks:
-pedal threads (as mentioned above) take pedals off, clean up threads and grease them.
-chainring bolts. clean, grease, tighten properly.
-seatpost. Take it out and clean it and the clamp. Lightly grease using the correct type of grease depending on seatpost material + frame material.
-headset. strip, clean, grease, make sure it's tight.
-derailleur hanger. take it off and make sure no dirt between it and frame. clean bolt threads.
Anyone tried the Wiggle Bibs? They're only £29.99 which looks good to me!
I trust wiggle for many things, but clothing is not one of them.Anyone tried the Wiggle Bibs? They're only £29.99 which looks good to me!
I'm considering picking up one of these: http://whyte.bike/gb/models/commuterroad/rd-7-road-disc/dorset/
Seems decently specced and well reviewed, but has anyone got any experience of Whyte?
Glad I asked then, because I'm not clued up on disc brakes. Really not bothered about the groupset on a commuter, but you're right the 105 is considerably better.
Trouble now is finding a dealer that I can get too when I'm over in August..
Link for the lazy: http://www.tourofbritain.co.uk/news/10829.php
I have a new challenge now though!
http://app.strava.com/activities/270020980
Anyhow. Another draftee this morning but this guy said hello and after half a mile took position ahead and offered to let me draft him for a bit. Much more reasonable![]()
My neighbour's left me a voicemail saying someone was parked up over the road in a van this morning and reckons they might have been casing my new asgard bike box. So now I get to worry about it getting broken into...
Seems decently specced and well reviewed, but has anyone got any experience of Whyte? Bear in mind that this is to kick start a "refurb" of my stable, replace my commuter with this, and later in the year look at purchasing a new road bike.
£1250 for Pinnacle Arkose 4, 105 5800, and full hydraulics!
Sorry I keep coming into this thread only to ask for opinions but I'm new to this buying a bike in bits thing.
I have some carbon handle bars that I don't want to use with the new frame as you're not supposed to put aero bars on them. Does anyone have any alloy handlebar recommendations for around £100?
Awesome cheers. Yes I think the Canyon is a little overkill. I wonder if that Suffolk is a new model? I'd bookmarked the Dorset a while back and just revisited it now as I'm looking through favourites of bikes I want to buy...If you wanted to go a bit higher and get something even better spec (proper hydraulic discs, ultegra) then the Canyon Inflite AL 9.0 is around £1400 also. I guess that's a bit much for a commuter though if you're planning to get a full-on road bike.
One thing with the Hy/Rds is that when you get the bike they are almost guaranteed to be set up incorrectly. If you do end up getting them be sure to check the technical bulletin on this page for info on how to properly set them up. It's not hard but until not that long ago the information wasn't really out there and in my experience a lot of bike shops don't seem to have updated their info.
http://www.trpbrakes.com/category.php?productid=1198&catid=206
Not sure where I'm staying but it will be SE, I have a place in the RideLondon.edit: Whereabouts in the UK will you be in August?
Bloody foreigners! Come over here and take our sportive places!![]()
!Awesome cheers. Yes I think the Canyon is a little overkill. I wonder if that Suffolk is a new model? I'd bookmarked the Dorset a while back and just revisited it now as I'm looking through favourites of bikes I want to buy...
