- 24 Aug 2006
- Gibraltar
That's been addressed now.
In a day its been addressed?
It's a fast card I'm not denying that. It just ain't that fast.
I hope this card will drop the price of the current 980's so i could just grab a pair of this for SLI.
Do you think the 980's will drop in price, or will the future 980TI just be released at a more efficient price to match the 390x's?
Is it worth me changing my 2x R9 295X2's for 2x Titan X?
Thanks
980 won't drop until it gets replaced by the 980ti.
980 is now a mid range CARD and mid range PRICE (not silicon !, it was always mid range silicon !) and will only drop when the 980ti comes along and makes it entry level.
There's just such a massive gap in price between it and TX. So much so the 980 seems positively cheap compared to the TX.
Thanks
Yes what were you even thinking?!?!?!
Personally speaking though I would just remove one 295x2, sell it and then carry on as normal.
Yeah, I bought it as I wanted 4k @ 60fps - but nothing supports crossfire unfortunately.
I'm thinking SLI will have a better shot especially as I'm using 21:9 3440x1440 instead now...
In one of the review describe the x295 as a mess. It had the fps over the titan x but was not as smooth as the titan. I thought it was all about frame pacing and all that stuff?
only because it hasn't had drivers for ages, other reviews said the 295X2 would be a Ttian X killer once it's been sorted out...................unfortunately, it has a lack of RAM........ I think, not sure about that
Added a third to my setup, and apart from a little more heat I'm more than happy with it!! Makes gaming at 4k possible at full settings![]()
I often wonder how many people would actually buy the Titan if we didn't have the forum here for them to tell everyone they're doing so and the benchmarking threads.
It definitely has some kind of influence.
