The ACW-R is still a very effective gun, you wont be put off using it.
I'm sure it is, but knowing BF, as this gun has been slightly balanced, another will have taken the crown of OP!
you only have to unlock to play then when you enabled turn it off and play with normal pingyou dont leave it on
Found a fix. Join a server with the VPN, leave, turn off the VPN then join again. Shouldn't happen again as long as you leave origin open.
Pre loaded waiting for uk release don't want to use vpns as I'm not that dedicated of a fan. Look forward to playing. Does it release midnight tonight or is it midnight tomorrow ?
Cheers
Cheers
Would also like to know this.
Currently downloaded 4.5GB/30GB
@kiwi, I might try the vpn trick tonight, was playing BF4 with the TS crew last night. Is it any good then??
Too early for me to tell. I was getting instakilled a lot by higher ranking players last night and it didn't feel as smooth as the beta but not sure if that was the high ping players introducing lag or not. From the few maps I've played they generally seem better than the BF4 ones but I need more hours to form an opinion. I really like dust bowl and bank job from the beta.
It would be great to squad up tonight if you're on. Failing that wife is off to Spain for the weekend so I should be on Friday/Saturday/Sunday.
@VR: Not received a single crash. I actually copied my settings folder from BF4 Beta 2 HL directly into my BF HL folder and it transferred over the files. Perhaps you could try the same?
Would you guys say that it is a good game to get, I really liked BF3 and I only played the Beta on BF4
