** TRULY INSALE DEALS ON GTX 780Ti & GTX 770!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I have truly incredible pricing and to make this deal even better these cards are brand new, with genuine NVIDIA coolers. The 780Ti offers 970 performance and better, plus is a great upgrade for anyone currently with a 780Ti wanting to go SLI.
Then the GTX 770 is the real bargain, it out performs the GTX 960 at everything, especially higher resolutions and is a lower price and again features a genuine NVIDIA cooler.
OcUK GeForce GTX 780Ti "NVIDIA Reference" 3072MB GDDR5 PCI-Express Graphics Card @ £249.95 inc VAT
NVIDIA's latest Geforce 780Ti takes the fight right to the competition in the battle for current worlds fastest single GPU. Packing a fully enabled GK110 GPU with a whopping 2880 cuda cores this card has huge amounts of processing power to enable it to power through any game. Infact the 780 Ti is so impressive, it’s not just cheaper than TITAN, it beats it in performance and takes the crown as the Best Gaming GPU on the Planet.
NVIDIA are supporting the overclocking community even further with an advanced three rail PWM with load balancing, whereas older GTX 780 and Titan pulled all their power through three rails, they did not load balance. 780Ti's new PWM means it can source power from three sources and load balance resulting in the same amount of power from each rail, allowing for more superior overclocks and stability. Here at Overclockers UK we tested this and where we found Titans would top out at 1100-1150MHz core, whereas the 780Ti was able to hit 1200-1300Mhz core over and over again, proving this new PWM not only offers efficiency and stability, but also great overclocking ability. When overclocked this cards performance can be increased by upto a further 30%, making it a truly unstoppable force.
For memory once again here at Overclockers UK we are very impressed to see 3GB of RAM and a 384-Bit interface meaning it can power the latest games even at the highest resolutions and detail settings, making this card the perfect choice for any gamer or overclocker.
780Ti uses the Titan cooling system and this means that even whilst gaming, you can indeed game in silence or at night whilst the rest of the household is asleep and not have to worry about waking up those sleeping.
Specification:
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 876MHz
- Core Boost Clock: 928MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Features:
- MAX your overclocks with NVIDIA's Power Balancing
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)
- GPU Boost 2.0 Technology
- TITAN cooling system
Was [£349.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
OcUK GeForce GTX 770 "NVIDIA Reference" 4096MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory: 4096MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2170MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£299.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 770 "NVIDIA Reference" 2048MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
Features:-
Specification:-
- Memory: 2048MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£249.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
These cards represent unbeatable value for money and the quality is outstanding as they are all NVTM, so all using only NVIDIA specified components and coolers, in essence like our OcUK 970 NVIDIA reference, the quality is outstanding.
STOCKS ARE VERY LIMITED, BE QUICK!!
What's the recommended PSU for 780Ti SLI?
I've got a Windforce 3 at the moment, but the OCD part of me wants identical cards. Arrrg.
