So - I'm getting my first RDA, and I've decided on the Mutation X v2 over the Troll. I tend to vape at .5ohms on my Atlantis - which gauge kanthal wire should I get? I was looking at 26awg. That should be sufficient? Also, where is a good place to get the wire and cotton without paying too much. I've found 26awg wire for £5.99 for 10 metres; is that a good deal?
Damn beaten by both of ya. Damn iphone![]()
Stick with regular if you are new to building imo.
Also I linked the Arctic at top of this page (I would wait tilll my epack get them in) just incase you missed it![]()
Thanks guys for the links. IceShock - it was actually your influence that made me choose the Mutation X, as I've been following your comments and you seem to be chuffed to bits with it.
I will be using this with my Sigelei 100w. I think it will fire down to .15 Ohms. I suppose I ought to get an Ohms-metre as well.
Ordering now. This ought to keep me entertained until I pull the trigger on the Horizon Arctic!
EDIT - Do I want twisted or regular kanthal?
LOL... sorry.. I'm busy at work today building a server, no time to play.Thanks guys for the links. IceShock- it was actually your influence that made me choose the Mutation X, as I've been following your comments and you seem to be chuffed to bits with it.Your my hero!!!
ive said this before, but if you like the mutation, then check out the "Infinite CLT V2 Plus", it blows the Mutation v2 away on flavour and clouds as well, and is under £30 for an Authentic RDA, maybe not as cheap as the Mutation, but then its far better too and just as easy to build on.
So I mixed up my first batch of red astaire - and it's made me feel queezy to say the least.
VG based Nic72 coming out at 8mg (I kept it low as I'm using the 0.5ohm coil in my subtank) PG based Red Astaire at 10%. PG/VG @ 60/40
It's leaving a weird aftertaste that after continued use has me feeling a bit sick. Glad I only made up 10ml.
I'll make up another batch as per the T Juice website 80/20 with 15% of RA.
My subtank also leaked really bad this morning with no obvious reason why.
I followed the eLiquid calculator.
Nic - 1.1ml
PG - 5ml
VG - 2.89ml
Flavour - 1ml
It's like a rotten veg aftertaste - like biting into a sandwich and the lettuce has gone off.I topped up with off the shelf RA and I can hardly taste it now.
Does the PG or VG have a taste to it?
To be honest I don't really know the implications of the PG/VG mix only that higher VG gives a bigger cloud but can make the mix too thick. Is that right? Other than that I don't know any more.
