- 24 Mar 2011
- Kent
Well that's cool, there's no way of passing through hard drives on hyper-V without vt-D is there?
Yes.
To pass a physical drive through to a Hyper-V guest you need to open disk management,right click the drive then "offline" it. After that you can add the physical disk to a Virtual Machine through Hyper-V manager.
I converted my server to Server 2012 R2 yerterday for all of half an hour before it got on my nerves and wouldn't allow me to run Debian Guests correctly
Awesome! Much thanks
Just re-set up Xpenology with my 3TB storage drive set as offline, now to start the task of transferring all my media/games across. Had some issues with mapping the network drives onto my Windows PC (server could see them fine but PC couldn't connect) I ended up mapping them using the Synology Assistant tool).
If I need to add another disk i can just slot it in, set it to offline, add it in Hyper-v and add to Synology via the software.![]()
Hey folks,
I've a N40L that I use as a HTPC. I'm looking to get a new TV cabinet and I'm wondering how much ventilation it needs? The cabinet I'm looking at has only 2 open parts which I need for my amp and sky box. I was planning on putting the server into the cupboard part of tge cabinet, although I was going to cut out the back of it both to improve be ventilation and for the cables. Would this be ok?
Those of you that use it as a HTPC, where do you put it?
Thanks!
I had my N54L with 3x HDDs in a closed cupboard for a week. When I opened the doors the wall of heat was impressive!
How big of a drive do you need for the OS on one of these, assuming it was just for fileserving/plex media.
I assume i should have the os on a separate drive to the data, so assuming a linux server would i be better off getting some sort of small ssd for the OS and having my WD Reds for the data?
For size 60GB for OS would be more than ample
I'm using no more than 20gb with Debian
Gen 8 £119.99 after cashback now.
So anyone who bought one before the end of march only gets £30 cashback but if you buy one now (a week later) you get double the amount back...
Wow prices came down fast! Def tempted now sat £120 is a bargain.
How much better is the Gen8 then the N40L? I'm using it as a HTPC with Kodi and possibly plex in the future. I see it only has 2gb ram included, assume more ECC is going to be expensive??
