They look great together. But which one sounds the best?![]()
- Everything else will be simply throwing money at a non CSL for no reason and then the faff of putting it back to stock if you get rid of the car and selling them on etc.It was a maybe tweak anyway but the price jacking up is the nail in the coffin tbh so I will just keep as is. The rag top makes the sound enter the cabin much more than the coupe anyway so it sounds really sweet.
Going by the PH discussion on getting a CSL sound from a non CSL (link) - Seems the only proper way is to get a CSL- Everything else will be simply throwing money at a non CSL for no reason and then the faff of putting it back to stock if you get rid of the car and selling them on etc.
That is only a (large) portion of the sound. The rest comes from the exhaust, lack of sound deadening under the floor panels (for inside the cabin sounds) and the ECU map which changes throttle calibration, raises the redline a bit and some other stuff.
If you went for a drive in a CSL, and then straight after in a "normal" M3 with a CSL air box you would really struggle to tell any difference except for the lack of sound deadening. The GSR air box with a couple of mods sounds almost as good.
Sounds a bit **** if I'm being honest here. Sounds unnatural if that makes sense.
Sounds like a saxo with a bean can exhaust to me.![]()
It really doesn't in real life. Videos always make things sound different. IRL it sounds really, really nice.
Of course but would you not agree that it's literally throwing money to improve an already good sound? And then there's the case of potential resale value (I know I've said I have little desire to sell this car down the line but I'd like to keep things minimal in terms of under bonnet mods if I can). All the thousands spent and it won't put a dent into the sale price years down the line to someone looking for a close to mint motor, so you'd want to ideally fit back the stock components and sell the CSL components, unless the buyer you sell the car to is specifically after the whole setup fitted anyway.
I'm all for making things nicer but £1000+ for just sound and whatever the small HP bump might be doesn't seem a wise move to me. £500 for the Evolve pre-order deal was brilliant, I had it in mind to do that, just never thought they'd jack it up to over £1000 in the end :/
I'd rather put that money aside and spend it in years to come on a full respray once scratches and stone chips accumulate and get annoying!
I think with the convertible I've gotten the good side of both worlds. I've got the brunt of the sound in the cabin by nature of the car anyway, and on the road it sounds great too. Granted it's not CSL great but it definitely stands out and to my ears is the most pleasing and "analogue" sounding vs other generations/other cars, if that makes sense.
