Missed my delivery yesterday, so should come today!...
Just got a quick question or two... What's the largest size MicroSD card that this baby will take? What's the best make/model MicroSD card this baby will take??!!![]()
You do realise you can open up multiple windows in modern IE?
Long press on the tab and select open in new window. It is effectively two modern IE open side by side.
Unless that doesn't work due to screen res.
I mean more than one actual Browser. If I set IE as my default browser it opens in Modern UI, but then Chrome will always open the Desktop version. If I change Chrome to open in Windows 8 mode then it bumps IE off of the Default spot and then that only opens in Desktop mode
Why can I not have both IE and Chrome open in the Modern UI mode by default
Mines got a 64GB Samsung microSDXC card in and it works fine. Although I've not found much use for it yet as I cant seem to find a way to install apps to it?
Why can I not have both IE and Chrome open in the Modern UI mode by default![]()
Umm... What? Chrome only has a desktop version for windows 8.
It's just the way it works, no way around it. To be fair the ModernUI IE is pretty good and I exclusively use it on my tablet.
