Check out these new EVGA SLI Bridges !!!!
Man of Honour
21 May 2012
Dalek flagship
http://www.evga.com/articles/00919/EVGA-Pro-SLI-Bridges-V2/
"they also have a high quality aluminum shroud and are optimized for the next generation display resolutions and refresh rates, with a high pixel clock frequency design that gives best performance for 120Hz+ and 4K+ gaming!"
So how does that differ from the ribbon cable you get with the motherboard? Are they really any different internally? I got sucked in with the last ones, still trying to offload it on the MM :D.
there's no difference, they just look awesome, you're buying for the looks.
So when you're gaming you can look at the bridge and not at your screen.
I suppose you're right, I'm just of an age where I don't consider making my PC look like a dutch prostitute's window as superior aesthetics. :D
