[RXP]Andy;27890346 said:Has anyone used Ammo NYC stuff for cleaning the car? I've been watching some of Larry's videos and they are pretty informative.
thanks I have the trim , ill use that tomorrow then for the external plastics and rubber seals (like around the doors)
what's good for the interior then ? , I was thinking of getting the interior shampoo to do the dash ? or shall I use the vinyl and rubber care?
It needs to be a limescale type remover. So anything that removes limescale.
AG Interior Shampoo can be used on pretty much any interior surface. I use it as a dash cleaner because it doesn't leave any residue behind so leaves everything with a clean matt finish.
If you want things to look shiny, Vinyl and Rubber Care is fine for interior plastic. You can control how shiny depending how long you leave it on for. It's also great on door seals and stops them sticking when cold.
Anyone recommend something to keep the exhaust tail pipes clean?
Could never se my MK4 Golfs exhaust but my MK7 pipes are, at the moment, shiny!
Great job, looks fantastic.Gave it a good going over with SRP, then a coat of EGP and finished with Poorboys Natty's blue.
I have a foam lance from Direct Hoses, which I believe is the same lance sold by Autobrite Direct and others. I have used it approx 20 times. Haven't been overly impressed with it since day one. So I decided to strip it and clean the gauze with neat descaler for about 15 minutes. Now it foams like an extra from Frozen!!! Well impressed![]()
What are people's thoughts on a California Duster, for dusting the car down in hot weather, when the sand/dust covers your car? Chance of scratching or safe?
