This is the routine I run with SLI/CFX.
a) Swap cards (the bottom card might be better in the top slot)
b) switch sidefan direction and/or create better positive pressure with other fans.
c) put a fan on the side of the HDD bay blowing over cards
d) replace GPU thermal paste with something like mx-4
(last resort measures below)
e) undervolt and underclock
f) place a big normal fan blowing full speed at the cards(used this one when mining with a custom open case)
If you can, I fitted the NZXT G10 to my SOC and dropped from 77c to 36c under full load.
If you have space you could sli them too, which it what i plan on doing.
Does this require an existing water cooled system?
