AMD - How To Overclock The Official Way Using Afterburner + Step By Step Overclocking Guide + Comple
Caporegime
OP
12 Jul 2007
United Kingdom
I'm not sure whats wrong, but i kept my core at 1150, and my mem to 1375 and got a score of 1911 on valley which was the highest yet, then i tried it on 1400 and the score dropped to 1700 something so i thought i had gone over its limit.
So i set it back to 1375 and cant get above 1800 again now. Not only that i'm looking in msi and the whole time i run the benchmark the core doesnt seem to be going quicker then around the ~900mhz speed, its throttling badly for some reason.
Use 13.12 drivers and ensure you have +50% power tune set. If you get a crash make sure you restart the pc and reapply clocks before trying again.
20 Oct 2011
Current settings :-
fans auto - volts (mv 1275)power limit +5 % 1115 + 1725 - temp =77 = score 2160
Is the temp are fair temp or it running too hot ?!
Where should i be going from here MV wise , Core and memory speeds....what is the max score i am likely to achieve ? as i may just leave it set as it is if for example , i am only likely to achieve a 2 % or so further improvement.
I do not want to over stress my card , as it is 2nd hand with no warranty , but i would like to overclock to a good speed but not over stress it :)
One thing i have noticed is that if the fans are on full or on auto at the current settings the temp remains pretty much the same.
Advice please ...
My system
VTX3D 7970 (core voltage unlocked) x-edition
amd 8350 running at 4414 mhz
ram DDR3 running at 16gb 2052 (2x8gb Ballistix crucical pc3 12800 cl8 1.5v)
Asus MB M5A97 LE R2.0
windows 7 64bit
Evo 840 250 SSD HD
XFX PSU PRO 550W
Cooler Master Case
Software running
Latest Beta Drivers for graphics card.
MSI
GPZ
Heaven vally bench mark settings :-
Preset :custom
API : DX11
Quality : High
Tess :Disabled
Stero 3d :Disabled
Multi Mon : Disabled
Anit A : Off
Full screen : Ticked / On
Res : 1920 x 1080
Test reports :-
Voltage is unlocked already on my VTX3D 7970 X-edition , i have checked this using the test method on page 1 :)
graphics card stock speed(1050 + 1425) , stock volts (1194) fan auto score 1923
fans auto - stock volts (mv 1194)1085 + 1575 = score 2035
fans auto - stock volts (mv 1194)1100 + 1625 temp = 72 score 2093
fans auto - stock volts (mv 1194)1100 + 1675 temp = score = 2123
fans auto - stock volts (mv 1194)1105 + 1700 temp 74 = 2133
fans auto - stock volts (mv 1194) 1115+ 1710 temp 74-75 = 2153
fans full 100% - stock volts (mv 1194)1115+ 1710 temp 74-75 = 2149 fans on full
Started to show artifacts ****fans full 100% - stock volts (mv 1194)1125+ 1725 temp 74-75 = 2166 fans on full ***
Scaled back graphics 100 % fine no artifacts ****fans auto - stock volts (mv 1194)1110 + 1725 - temp 70 = 2152 fans on full ****
fans on full - volts (mv 1250)1110 + 1725 - temp 74 = 2121
Power limit set to std + 0
C64
C64
16 Mar 2007
London
Just got a 7950 and noticed gpu-z reports voltages wrong ? I put in 1.00 volts and it's reporting back as it's hitting 1.498 volts when I run heaven bench and click on max voltage hit sensor on gpu-z VDCC.How can it hit 1.498 volts the limit is 1.3 on msi afterburner ?
14 Dec 2011
Does anyone know if the overclocking method on post 1 is still current for overclocking crossfire 7950's on win10? I have sourced the latest versions of the programs mentioned there. Since I want to start playing about with this.
14 Dec 2011
Hi Matt,
Thanks for letting me know. Is there an official stance on 1 bridge or 2? as when I went to 2 bridges, the firestrike bench just seemed a bit smoother and got a small 11 point bump (which could be a fluke).
Caporegime
OP
12 Jul 2007
United Kingdom
Hi Matt,
It's been a while since i tested it to be honest, but from memory i don't recall there being any difference. If you have two bridges attached only one is used.
13 Jun 2009
My card seems to be voltage locked but I can bump it from 945 MHz to 1000 MHz. Got driver crashes at 1025 MHz unfortunately. Haven't tried to find max VRAM clock yet but a bump from 1400 MHz to 1450 MHz works. Was stable for a 4 hour Dying Light session. :D
