I would like to try GTA V pre patch to see if mine hit 99%, is that even possible?
Prob the only way to confirm it tbh... not sure now though as it's through Steam
Uninstall Rivatuner it doesn't really play well with SLI.
How are you supposed to check GPU usage then?![]()
I'm sure I uninstalled Rivatuner and the usage was just the same (Afterburner shows GPU usage without Rivatuner).
Could someone else confirm it's not Rivatuner causing this? I'm 99% sure it's the driver or the game at fault.
GPU-Z works
The FPS don't seem too far off.
If you want to see better scaling, then maybe enable MSAA 2x, but obviously you may take an FPS hit. You may just be seeing the limits of the API.
What does that mean? 'limits of the API'
Unfortunately, I'm sinking below 60 regularly and averaging around 70.
There's definitely something not right, I just can't think what it is.![]()
Are right, so basically requires more CPU because of the bigger world and more stuff going on. As opposed to say Crysis 3 where the graphics are better but its a linear game
