On the spec it says that it has 2x2w speakers - how do I get audio to work through the DP cable?
Cheers![]()
Cheers![]()
it doesn't have any speakers, the OcUK spec for that part is incorrect
As far as I am aware G-sync disables the audio.
This is mine, no dead pixels (yet)
I am starting to think there may be a genuine conspiracy among panel manufacturers to continue producing crappy panels with ridiculous bleed/glow issues, until we all get so used to it that we just accept it as normal. We're already halfway there it seems! Unacceptable. I will not buy a new monitor until these problems are resolved, and I would encourage everyone else to do the same. Only when their bottom lines start to suffer will anything be done about this.
Same here. After running Dead pixel tests I have a stuck pixel in the top right and on the blue screen there is a pixel stuck on black in the bottom left corner. what to do now :s
That won't fix the backlight bleed which is worse.
