Didnt consider the Gyre over those new QD pumps then?
Yes i did, and i was very close in buying the Gyre, but what i read on how many failed it did put me off buying, yes i could have saved £350 but i think i made right choice
I always say, there's a special switch on these machines.![]()
Needed a new media center device, was going to get a Fire Tv Stick and install XMBC/Kodi on it, but no USB ports, I need USB ports unfortunatly for my hard drives.
Opted for a Raspberry Pi 2 instead and got it a little case.
£40 in total for Pi + case and the SD card which is a Sandisk 8gb class 10
Works very nice with kodi installed, nice and quick.
plugged in a very old wifi usb stick I had laying around (thats why its so big!) works great.
Got it powered by my TV's USB and set CEC to turn on the Pi when my Tv turns on, and turn it off when I turn my TV off and I can use my TV remote to control the menus.
Very happy with it.
Which case is that please?
Yes i did, and i was very close in buying the Gyre, but what i read on how many failed it did put me off buying, yes i could have saved £350 but i think i made right choice![]()
Fair enough pal - been on the fence about changing my 2 x MP10's for the Gyre.. not worth the QD upgrade![]()
Decided to get myself a GoPro 'copy' - the SJ4000. Added the mount to my bike (normally this is the under handlebar one, but I wanted a view including the brake hoods, so this works well). Only issue is I can't use my Garmin on the stem anymore, so ordered a out front mount for the other side - but not arrived yet!
Not bad for £40!
