- 3 May 2004
- Democratic People’s Republic of West Surrey
I used Tub Tape on mine. It's pretty sticky stuff. I use a lot of adhesives at work for all sorts of stuff and tape is WAY less faff than anything else I could imagine for gluing a tyre on with. Tub Tape and Tufo tape both have strong plastic backing that you can pull out from the side of the tyre after you are happy with the position of the tyre on the rim - it's SO easy to apply and seems to be stuck on more than adequately.So, any recommendations for 25mm tubs before I get some Vittoria Corsas? Also, do I need glue or is Tufo extreme tape sufficient?
