Dirt Rally Benchmark
Status
Not open for further replies.
Caporegime
12 Jul 2007
United Kingdom
Settings.
To run the benchmark you need to go to options and extras, then graphics, then benchmark mode.
Please use x8 MSAA and the Ultra Preset.
Simple Rules.
Any normal resolution can be used up to and including 4K.
Please post your GPU and CPU clocks.
Please post what drivers you are using.
Please include original full size HQ screenshots and use spoiler tags.
Please post your result in the text format as shown below in the spoiler.
Please include the XML results file and wrap it in a spoiler as below.
1 x 285 @938/1375
5960x @4.0
15.4 Drivers
DX11
1080P
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Benchmark Mode Results -->
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="AMDMatt" date="09:22:46 on 09/05/2015" machine="Matt">
<totals races="1" total_time="00:03:08" total_race_time="00:03:08" race_time="00:03:08" />
<fps_race min_fps="43.493847" max_fps="80.071449" av_fps="55.732346" min_fps_ms="22.991758" max_fps_ms="12.488846" av_fps_ms="17.942902" />
<fps_total min_fps="43.493847" max_fps="80.071449" av_fps="55.732346" min_fps_ms="22.991758" max_fps_ms="12.488846" av_fps_ms="17.942902" />
<track index="1" numInRotation="1" totalProfiled="1">
<results samples="10490" min_fps="43.493847" max_fps="80.071449" av_fps="55.732346" min_fps_ms="22.991758" max_fps_ms="12.488846" av_fps_ms="17.942902" battery_percentage_used="0" />
<settings name="hafren_rally_01" route="route_2">
<car name="555" livery="17" />
</settings>
</track>
<hardware_settings_config version="8" deviceId="0x6939">
<cpu>
<threadStrategy workerMapFile="system/workerMap8Core.xml" forceFeedbackProcessor="6" dvdStorageProcessor="7" dataSetMonitorProcessor="4" renderProcessor="0" updateProcessor="2" fileStreamProcessor="5" />
</cpu>
<audio_card>
<dynamic_range value="high" />
<eq value="flat" />
</audio_card>
<graphics_card rating="1" firstBoot="true">
<directx forcedx10="false" />
<eyefinity force="" osd="" />
<stereo enabled="false" separation="0.015" convergence="0.5" />
<resolution width="1920" height="1080" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="59" />
</resolution>
<gamma level="0.8" />
</graphics_card>
<shadows enabled="true" size="3072" maskQuality="2" particles="true" />
<advanced_fog enabled="true" />
<particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
<weather quality="1" />
<crowd enabled="true" detail="4" />
<cloth enabled="true" tessellation="true" />
<groundcover mode="ultra" clutter="true" />
<objects lod="1.02" maxlod="0" stones="true" />
<trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false" />
<vehicles characterQuality="4" lodQuality="3" />
<track lod="1.0" />
<envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0" />
<water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
<mirrors enabled="true" width="768" height="256" car_maxlod="2" car_culldist="300.0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" quality="4" />
<dynamic_ambient_occ_soft enabled="true" />
<night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
<textures resolution="3" />
<shaders quality="2" low_quality="false" />
<anisotropic min="4" max="16" />
<physics environmentalDamage="true" vehicleDamage="true" />
<input device_type="auto" />
<motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0" />
<screenshotMode enabled="false" />
<aoit enabled="false" />
<avsm enabled="true" />
<oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" />
</hardware_settings_config>
</benchmark>
1080p
1 GPU
  1. Score 130.48 GPU TitanX @1471/2002, CPU 5960x @4.6, Kaapstad Link 350.12 Drivers
  2. Score 102.57 GPU Fury @1140/545, CPU 4790k @4.5, nashathedog Link 16.7.3 Drivers
  3. Score 97.98 GPU 290X @1230/1625, CPU 5960x @4.6, Kaapstad Link 15.4 Drivers
  4. Score 90.28 GPU 295x1 @1175/1625, CPU 5960x @4.0, AMDMatt Link 15.4 Drivers
  5. Score 84.87 GPU 980 @1405/1851, CPU 3820 @4.3, coupe69 Link 350.12 Drivers
  6. Score 83.02 GPU 290X @1175/1625, CPU 4690k @4.7, savagesam117 Link 15.4 Drivers
  7. Score 82.25 GPU 970 @1515/1980, CPU 4790k @4.4, madp0k Link 350.12 Drivers
  8. Score 81.48 GPU 970 @1506/2003, CPU 4770k @4.2, GamingSlug Link 350.12 Drivers
  9. Score 71.41 GPU RX480 @1400/1750, CPU 6700k @4.8, MyBrains Link 17.8.1 Drivers
  10. Score 71.35 GPU 290 @1000/1300, CPU 2700k @4.4, HeX Link 15.3 Drivers
  11. Score 58.10 GPU 7970 @1150/1660, CPU 3770k @4.0, wazza300 Link 14.11.2 Drivers
  12. Score 55.73 GPU 285 @1200/1500, CPU 5960x @4.0, AMDMatt Link 15.4 Drivers
2 GPUs
  1. Score 157.99 GPU TitanX @1002/1753, CPU 4790kx @4.5, Hammerark Link 353.62 Drivers
  2. Score 112.20 GPU 970 @1506/2003, CPU 4770k @4.2, GamingSlug Link 350.12 Drivers
3 GPUs
4 GPUs
1440p
1 GPU
  1. Score 135.28 GPU 1080 @2050/5400, CPU 6850k @3.8, Gregster Link 368.81 Drivers
  2. Score 91.67 GPU TitanX @1471/2002, CPU 5960x @4.6, Kaapstad Link 350.12 Drivers
  3. Score 71.92 GPU 290X @1230/1625, CPU 5960x @4.6, Kaapstad Link 15.4 Drivers
  4. Score 69.21 GPU FuryX @1050/500, CPU 5930k @3.5, FredFlint Link 15.7.1 Drivers
  5. Score 59.24 GPU 980 @1405/1851, CPU 3820 @4.3, coupe69 Link 350.12 Drivers
  6. Score 39.24 GPU 285 @1200/1500, CPU 5960x @4.0, AMDMatt Link 15.4 Drivers
2 GPUs
  1. Score 111.66 GPU TitanX @1253/1753, CPU 5930k @4.3, Klunt Bumskrint Link 352.86 Drivers
  2. Score 28.32 GPU 670 @1001/1528, CPU 4930k @4.4, OLDPHART Link 353.06 Drivers
3 GPUs
4 GPUs
1600p
1 GPU
  1. Score 85.56 GPU TitanX @1471/2002, CPU 5960x @4.6, Kaapstad Link 350.12 Drivers
2 GPUs
3 GPUs
4 GPUs
3440 x 1440p
1 GPU
  1. Score 75.15 GPU Vega 64 @1667/945, CPU 4790k @4.5, nashathedog Link 17.8.1 Drivers
  2. Score 61.42 GPU Fury @1130/500, CPU 4790k @4.5, nashathedog Link 17.1.1 Drivers
2 GPUs
  1. Score 99.73 GPU TitanX @1002/1753, CPU 4790kx @4.5, Hammerark Link 353.62 Drivers
3 GPUs
4 GPUs
The Ultimate - 2160P
1 GPU
  1. Score 50.20 GPU TitanX @1471/2002, CPU 5960x @4.6, Kaapstad Link 350.12 Drivers
  2. Score 42.32 GPU Fury X @1125/500, CPU 5960x @4.9, AMDMatt Link 15.15 Drivers
  3. Score 41.85 GPU 290X @1230/1625, CPU 5960x @4.6, Kaapstad Link 15.4 Drivers
  4. Score 12.85 GPU 285 @1200/1500, CPU 5960x @4.0, AMDMatt Link 15.4 Drivers
2 GPUs
  1. Score 79.31 GPU Fury X @1125/500, CPU 5960x @4.9, AMDMatt Link 15.15 Drivers
3 GPUs
  1. Score 116.24 GPU Fury X @1125/500, CPU 5960x @4.9, AMDMatt Link 15.15 Drivers
4 GPUs
  1. Score 146.05 GPU Fury X @1125/500, CPU 5960x @4.9, AMDMatt Link 15.15 Drivers
Single TitanX @1455/2002
5960X @4.0
350.12 drivers
2160p
<?xml version="1.0" encoding="UTF-8"?>
-<benchmark machine="HAL" date="15:24:27 on 06/05/2015" author="Keve" instruction_set="SSE2" directx11_feature_level="11.0">
<totals race_time="00:03:08" total_race_time="00:03:08" total_time="00:03:08" races="1"/>
<fps_race av_fps_ms="19.963949" max_fps_ms="17.004955" min_fps_ms="23.125273" av_fps="50.090290" max_fps="58.806385" min_fps="43.242733"/>
<fps_total av_fps_ms="19.963949" max_fps_ms="17.004955" min_fps_ms="23.125273" av_fps="50.090290" max_fps="58.806385" min_fps="43.242733"/>
-<track totalProfiled="1" numInRotation="1" index="1">
<results av_fps_ms="19.963949" max_fps_ms="17.004955" min_fps_ms="23.125273" av_fps="50.090290" max_fps="58.806385" min_fps="43.242733" battery_percentage_used="0" samples="9428"/>
-<settings route="route_2" name="hafren_rally_01">
<car name="555" livery="17"/>
</settings>
</track>
-<hardware_settings_config deviceId="0x17C2" version="8">
-<cpu>
<threadStrategy fileStreamProcessor="5" updateProcessor="2" renderProcessor="0" dataSetMonitorProcessor="4" dvdStorageProcessor="7" forceFeedbackProcessor="6" workerMapFile="system/workerMap8Core.xml"/>
</cpu>
-<audio_card>
<dynamic_range value="high"/>
<eq value="flat"/>
</audio_card>
-<graphics_card firstBoot="true" rating="3">
<directx forcedx10="false"/>
<eyefinity osd="" force=""/>
<stereo convergence="0.5" separation="0.015" enabled="false"/>
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="auto" height="2160" width="3840">
<refreshRate rate="59"/>
</resolution>
<gamma level="0.8"/>
</graphics_card>
<shadows enabled="true" particles="true" maskQuality="2" size="3072"/>
<advanced_fog enabled="true"/>
<particles enabled="true" nearFadeBias="0" lowResScalar="2" dynamicRes="false" wind="true"/>
<weather quality="1"/>
<crowd enabled="true" detail="4"/>
<cloth enabled="true" tessellation="true"/>
<groundcover clutter="true" mode="ultra"/>
<objects stones="true" maxlod="0" lod="1.02"/>
<trees maxlod="0" lod="1.2" meshes_in_all_passes="false" meshes="true"/>
<vehicles lodQuality="3" characterQuality="4"/>
<track lod="1.0"/>
<envmap size="1024" mindistance="150.0" scaleminsize="0.75" drawallobjects="true" faces="6"/>
<water detail="3" tessellation="true" drawallobjects="true" scale="2" update="true"/>
<mirrors enabled="true" height="256" width="768" car_culldist="300.0" car_maxlod="2"/>
<skidmarks enabled="true"/>
<dynamic_ambient_occ enabled="true" quality="4"/>
<dynamic_ambient_occ_soft enabled="true"/>
<night_lighting shadowSize="2048" onlyHeadlights="false" shadows="true" lights="0" volumes="true"/>
<textures resolution="3"/>
<shaders quality="2" low_quality="false"/>
<anisotropic max="16" min="4"/>
<physics vehicleDamage="true" environmentalDamage="true"/>
<input device_type="auto"/>
<motion enabled="true" extradata="0" delay="1" port="20777" ip="dbox"/>
<screenshotMode enabled="false"/>
<aoit enabled="false"/>
<avsm enabled="true"/>
<oculus convergence="1.0" enabled="true" verticalOrientation="0.66" overdrive="true" vignette="true" timeWarp="true" chromatic="true" headMovement="true"/>
</benchmark>
5960x @4Ghz
1xR9 285 @1200/1500
15.4 Beta
1080P
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
1440P
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="AMDMatt" date="09:30:16 on 09/05/2015" machine="Matt">
<fps_race min_fps="29.277409" max_fps="53.135345" av_fps="39.237682" min_fps_ms="34.156029" max_fps_ms="18.819864" av_fps_ms="25.485704" />
<fps_total min_fps="29.277409" max_fps="53.135345" av_fps="39.237682" min_fps_ms="34.156029" max_fps_ms="18.819864" av_fps_ms="25.485704" />
<results samples="7386" min_fps="29.277409" max_fps="53.135345" av_fps="39.237682" min_fps_ms="34.156029" max_fps_ms="18.819864" av_fps_ms="25.485704" battery_percentage_used="0" />
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<resolution width="2560" height="1440" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="60" />
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
2160P
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="AMDMatt" date="09:40:24 on 09/05/2015" machine="Matt">
<totals races="1" total_time="00:05:42" total_race_time="00:04:52" race_time="00:04:52" />
<fps_race min_fps="12.500002" max_fps="17.545349" av_fps="12.846124" min_fps_ms="79.999985" max_fps_ms="56.995163" av_fps_ms="77.844498" />
<fps_total min_fps="12.500002" max_fps="17.545349" av_fps="12.846124" min_fps_ms="79.999985" max_fps_ms="56.995163" av_fps_ms="77.844498" />
<results samples="3763" min_fps="12.500002" max_fps="17.545349" av_fps="12.846124" min_fps_ms="79.999985" max_fps_ms="56.995163" av_fps_ms="77.844498" battery_percentage_used="0" />
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<resolution width="3840" height="2160" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
4790k @4.4
1 x 970 1515/1980
350.12 Drivers
1080 Peas
-<benchmark machine="TangoBobster" date="09:55:42 on 09/05/2015" author="MPK" instruction_set="SSE2" directx11_feature_level="11.0">
<fps_race av_fps_ms="12.157660" max_fps_ms="9.878092" min_fps_ms="14.111684" av_fps="82.252670" max_fps="101.234123" min_fps="70.863266"/>
<fps_total av_fps_ms="12.157660" max_fps_ms="9.878092" min_fps_ms="14.111684" av_fps="82.252670" max_fps="101.234123" min_fps="70.863266"/>
<results av_fps_ms="12.157660" max_fps_ms="9.878092" min_fps_ms="14.111684" av_fps="82.252670" max_fps="101.234123" min_fps="70.863266" battery_percentage_used="0" samples="15481"/>
</settings>
</track>
-<hardware_settings_config deviceId="0x13C2" version="8">
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
-<graphics_card firstBoot="true" rating="4">
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="auto" height="1080" width="1920">
<refreshRate rate="60"/>
</resolution>
</graphics_card>
<track lod="1.0"/>
</benchmark>
4790k @4.4
1 x 970 1515/1980
350.12 Drivers
1080 Peas
</settings>
</track>
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0"/>
</benchmark>
Scoreboard updated. :)
5960x @4Ghz
1xR9 295x2 @1175/1625
15.4 Beta
1080P
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="AMDMatt" date="12:27:15 on 09/05/2015" machine="Matt">
<totals races="1" total_time="00:00:20" total_race_time="00:00:17" race_time="00:00:17" />
<fps_race min_fps="80.813568" max_fps="97.394051" av_fps="89.344696" min_fps_ms="12.374160" max_fps_ms="10.267568" av_fps_ms="11.192606" />
<fps_total min_fps="80.813568" max_fps="97.394051" av_fps="89.344696" min_fps_ms="12.374160" max_fps_ms="10.267568" av_fps_ms="11.192606" />
<results samples="1565" min_fps="80.813568" max_fps="97.394051" av_fps="89.344696" min_fps_ms="12.374160" max_fps_ms="10.267568" av_fps_ms="11.192606" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="8" deviceId="0x67B9">
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
Score 71.85 GPU 290 @1000/1300, CPU 2600K @4.4, Drivers 15.3 Beta
-<benchmark machine="Mark-PC" date="14:21:56 on 09/05/2015" author="Mark" instruction_set="SSE2" directx11_feature_level="11.0">
<fps_race av_fps_ms="13.917049" max_fps_ms="10.640491" min_fps_ms="17.264709" av_fps="71.854309" max_fps="93.980621" min_fps="57.921623"/>
<fps_total av_fps_ms="13.917049" max_fps_ms="10.640491" min_fps_ms="17.264709" av_fps="71.854309" max_fps="93.980621" min_fps="57.921623"/>
<results av_fps_ms="13.917049" max_fps_ms="10.640491" min_fps_ms="17.264709" av_fps="71.854309" max_fps="93.980621" min_fps="57.921623" battery_percentage_used="0" samples="13524"/>
</settings>
</track>
-<hardware_settings_config deviceId="0x67B1" version="8">
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
-<graphics_card firstBoot="true" rating="1">
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="16:9" height="1080" width="1920">
</resolution>
</graphics_card>
<track lod="1.0"/>
</benchmark>
Just a quick go with the GPU at stock, will do an OC run later on :)
</settings>
</track>
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0"/>
</benchmark>
And on the scoreboard. :)
Status
