1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dirt Rally Benchmark
Discussion in 'Graphics Cards' started by LtMatt, May 9, 2015.
  1. Telecaster
    Mobster
    Sounds good, I suppose they have to throw that crap in for the yanks, about time we had a proper Rally game.
  2. LtMatt
    Caporegime
    Scoreboard updated gents. :)
  3. Geeman1979
  4. FredFlint
    Wise Guy
    5930K @stock 3.5Ghz
    290X (8GB) Vapor X @stock 1030/1375 driver = 15.4
    1440p
    [​IMG]
    <?xml version="1.0" encoding="UTF-8" ?>
    <!-- Benchmark Mode Results -->
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Flint" date="18:00:41 on 10/05/2015" machine="FlintBox">
    <totals races="1" total_time="00:03:08" total_race_time="00:03:08" race_time="00:03:08" />
    <fps_race min_fps="49.826672" max_fps="79.323677" av_fps="60.672455" min_fps_ms="20.069572" max_fps_ms="12.606577" av_fps_ms="16.481943" />
    <fps_total min_fps="49.826672" max_fps="79.323677" av_fps="60.672455" min_fps_ms="20.069572" max_fps_ms="12.606577" av_fps_ms="16.481943" />
    <track index="1" numInRotation="1" totalProfiled="1">
    <results samples="11419" min_fps="49.826672" max_fps="79.323677" av_fps="60.672455" min_fps_ms="20.069572" max_fps_ms="12.606577" av_fps_ms="16.481943" battery_percentage_used="0" />
    <settings name="hafren_rally_01" route="route_2">
    <car name="555" livery="17" />
    </settings>
    </track>
    <hardware_settings_config version="8" deviceId="0x67B0">
    <cpu>
    <threadStrategy workerMapFile="system/workerMap8Core.xml" forceFeedbackProcessor="6" dvdStorageProcessor="7" dataSetMonitorProcessor="4" renderProcessor="0" updateProcessor="2" fileStreamProcessor="5" />
    </cpu>
    <audio_card>
    <dynamic_range value="high" />
    <eq value="flat" />
    </audio_card>
    <graphics_card rating="1" firstBoot="true">
    <directx forcedx10="false" />
    <eyefinity force="" osd="" />
    <stereo enabled="false" separation="0.015" convergence="0.5" />
    <resolution width="2560" height="1440" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
    <refreshRate rate="60" />
    </resolution>
    <gamma level="0.8" />
    </graphics_card>
    <shadows enabled="true" size="3072" maskQuality="2" particles="true" />
    <advanced_fog enabled="true" />
    <particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
    <weather quality="1" />
    <crowd enabled="true" detail="4" />
    <cloth enabled="true" tessellation="true" />
    <groundcover mode="ultra" clutter="true" />
    <objects lod="1.02" maxlod="0" stones="true" />
    <trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false" />
    <vehicles characterQuality="4" lodQuality="3" />
    <track lod="1.0" />
    <envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0" />
    <water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
    <mirrors enabled="true" width="768" height="256" car_maxlod="2" car_culldist="300.0" />
    <skidmarks enabled="true" />
    <dynamic_ambient_occ enabled="true" quality="4" />
    <dynamic_ambient_occ_soft enabled="true" />
    <night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
    <textures resolution="3" />
    <shaders quality="2" low_quality="false" />
    <anisotropic min="4" max="16" />
    <physics environmentalDamage="true" vehicleDamage="true" />
    <input device_type="auto" />
    <motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0" />
    <screenshotMode enabled="false" />
    <aoit enabled="false" />
    <avsm enabled="true" />
    <oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" />
    </hardware_settings_config>
    </benchmark>
  5. LtMatt
    Caporegime
    Scoreboard updated Fred. :)
    In future please make sure you include a original full size screenshot. You can setup MSI Afterburner to take screenshots, please see my thread here for more info.
  6. ~>Dg<~
    Caporegime
    its a amd game lol. if it dont i would quit :p
    i cant believe no one has posted a screenshot with the big AMD banners in at every checkpoint :D
    on to the actual game this game is better than project cars and assetto . the thing is you really need to learn the game and many haven't put in the effort to get the best of it yet.
  7. Klunt Bumskrint
    Wise Guy
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Klunt" date="22:11:43 on 10/06/2015" machine="Nick">
    <fps_race min_fps="98.332634" max_fps="125.867645" av_fps="111.656960" min_fps_ms="10.169564" max_fps_ms="7.944853" av_fps_ms="8.956002" />
    <fps_total min_fps="98.332634" max_fps="125.867645" av_fps="111.656960" min_fps_ms="10.169564" max_fps_ms="7.944853" av_fps_ms="8.956002" />
    <results samples="21017" min_fps="98.332634" max_fps="125.867645" av_fps="111.656960" min_fps_ms="10.169564" max_fps_ms="7.944853" av_fps_ms="8.956002" battery_percentage_used="0" />
    </settings>
    </track>
    <hardware_settings_config version="8" deviceId="0x17C2">
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    <graphics_card rating="3" firstBoot="true">
    <resolution width="2560" height="1440" aspect="16:9" fullscreen="true" vsync="0" multisampling="8xmsaa">
    <refreshRate rate="144" />
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
    [​IMG]
    No idea if thats good!
    Titan X SLI @ 1253MHz
    Driver version 352.86
    5930K @ 4.2GHz
    1440peasinapod
  8. LtMatt
    Caporegime
    If you want to officially submit an entry please read the OP for instructions on how to post your result.
  9. OLDPHART
    2560x1440p / 4930@4.4GB / SLi 4GB 670@1001-1528MHz / 353.06 Drivers
    [​IMG]
    <!--Benchmark Mode Results-->
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="chris" date="07:05:41 on 11/06/2015" machine="chrisPC">
    <fps_race min_fps="22.774353" max_fps="34.437527" av_fps="28.319853" min_fps_ms="43.909042" max_fps_ms="29.038090" av_fps_ms="35.310917" />
    <fps_total min_fps="22.774353" max_fps="34.437527" av_fps="28.319853" min_fps_ms="43.909042" max_fps_ms="29.038090" av_fps_ms="35.310917" />
    <results samples="5333" min_fps="22.774353" max_fps="34.437527" av_fps="28.319853" min_fps_ms="43.909042" max_fps_ms="29.038090" av_fps_ms="35.310917" battery_percentage_used="0" />
    </settings>
    </track>
    <hardware_settings_config version="8" deviceId="0x1189">
    <cpu>
    </cpu>
    <audio_card>
    <eq value="headphones" />
    </audio_card>
    <refreshRate rate="76" />
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
  10. LtMatt
    Caporegime
    Thanks, scoreboard updated. :)
  11. Klunt Bumskrint
    Wise Guy
    I edited the post
  12. LtMatt
    Caporegime
    What speed was the memory running at, stock?
    Scoreboard updated. :)
  13. Klunt Bumskrint
    Wise Guy
    Yeah stock, these are stock SC clocks
  14. OLDPHART
    LoL, had Dirt since Sunday still using 1st gear to 3rd mainly 2nd, its all about skill you caught just expect to tear round and get fast times.
    Cracking game + 2 tips 1:steering wheel+pedals is a must more precise, 2:read up on Stage Notes makes life easier for example:R4 100 L6
    R4>Righthand Corner 4=Grade/Radius of Corner from 6 to 1 lower the number tighter the corner.
    100>Distance to next Corner.
    L6>Lefthand Corner 6=Grade/Radius of Corner.
    Since switching from a 360 pad to a steering wheel+pedals and learning what stage notes mean times improving and having far less mistakes.
  15. TTomax
    4790K @ 4.8GHz / TitanX SLI 1291/1750
    Driver version 352.86 iCafe 352.94 1440p
    http://www.kepfeltoltes.hu/150613/DirtRally_www.kepfeltoltes.hu_.png
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="TTomax" date="03:01:48 on 13/06/2015" machine="TT">
    <totals races="1" total_time="00:03:08" total_race_time="00:03:08" race_time="00:03:08"/>
    <fps_race min_fps="107.122101" max_fps="140.520462" av_fps="123.513031" min_fps_ms="9.335142" max_fps_ms="7.116401" av_fps_ms="8.096312"/>
    <fps_total min_fps="107.122101" max_fps="140.520462" av_fps="123.513031" min_fps_ms="9.335142" max_fps_ms="7.116401" av_fps_ms="8.096312"/>
    <results samples="23249" min_fps="107.122101" max_fps="140.520462" av_fps="123.513031" min_fps_ms="9.335142" max_fps_ms="7.116401" av_fps_ms="8.096312" battery_percentage_used="0"/>
    <car name="555" livery="17"/>
    </settings>
    </track>
    <cpu>
    <threadStrategy workerMapFile="system/workerMap8Core.xml" forceFeedbackProcessor="6" dvdStorageProcessor="7" dataSetMonitorProcessor="4" renderProcessor="0" updateProcessor="2" fileStreamProcessor="5"/>
    </cpu>
    <audio_card>
    <dynamic_range value="high"/>
    <eq value="flat"/>
    </audio_card>
    <directx forcedx10="false"/>
    <eyefinity force="" osd=""/>
    <stereo enabled="false" separation="0.015" convergence="0.5"/>
    <refreshRate rate="144"/>
    </resolution>
    <gamma level="0.8"/>
    </graphics_card>
    <shadows enabled="true" size="3072" maskQuality="2" particles="true"/>
    <advanced_fog enabled="true"/>
    <particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0"/>
    <weather quality="1"/>
    <crowd enabled="true" detail="4"/>
    <cloth enabled="true" tessellation="true"/>
    <groundcover mode="ultra" clutter="true"/>
    <objects lod="1.02" maxlod="0" stones="true"/>
    <trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false"/>
    <vehicles characterQuality="4" lodQuality="3"/>
    <track lod="1.0"/>
    <envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0"/>
    <water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true"/>
    <mirrors enabled="true" width="768" height="256" car_maxlod="2" car_culldist="300.0"/>
    <skidmarks enabled="true"/>
    <dynamic_ambient_occ enabled="true" quality="4"/>
    <dynamic_ambient_occ_soft enabled="true"/>
    <night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048"/>
    <textures resolution="3"/>
    <shaders quality="2" low_quality="false"/>
    <anisotropic min="4" max="16"/>
    <physics environmentalDamage="true" vehicleDamage="true"/>
    <input device_type="auto"/>
    <motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0"/>
    <screenshotMode enabled="false"/>
    <aoit enabled="false"/>
    <avsm enabled="true"/>
    <oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66"/>
    </benchmark>
  16. LtMatt
    Caporegime
    5960x @4.9Ghz
    1x Fury X @1125/500Mhz
    15.15
    2160P
    [​IMG]
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Matt" date="11:43:06 on 25/06/2015" machine="Home">
    <fps_race min_fps="32.554703" max_fps="53.415062" av_fps="42.322220" min_fps_ms="30.717527" max_fps_ms="18.721312" av_fps_ms="23.628250" />
    <fps_total min_fps="32.554703" max_fps="53.415062" av_fps="42.322220" min_fps_ms="30.717527" max_fps_ms="18.721312" av_fps_ms="23.628250" />
    <results samples="7971" min_fps="32.554703" max_fps="53.415062" av_fps="42.322220" min_fps_ms="30.717527" max_fps_ms="18.721312" av_fps_ms="23.628250" battery_percentage_used="0" />
    </settings>
    </track>
    <hardware_settings_config version="8" deviceId="0x7300">
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    <resolution width="3840" height="2160" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
    5960x @4.9Ghz
    2x Fury X @1125/500Mhz
    15.15
    2160P
    [​IMG]
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Matt" date="12:50:54 on 28/06/2015" machine="Home">
    <fps_race min_fps="59.798866" max_fps="98.175682" av_fps="79.311409" min_fps_ms="16.722725" max_fps_ms="10.185822" av_fps_ms="12.608526" />
    <fps_total min_fps="59.798866" max_fps="98.175682" av_fps="79.311409" min_fps_ms="16.722725" max_fps_ms="10.185822" av_fps_ms="12.608526" />
    <results samples="14928" min_fps="59.798866" max_fps="98.175682" av_fps="79.311409" min_fps_ms="16.722725" max_fps_ms="10.185822" av_fps_ms="12.608526" battery_percentage_used="0" />
    </settings>
    </track>
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
    5960x @4.9Ghz
    3x Fury X @1125/500Mhz
    15.15
    2160P
    [​IMG]
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Matt" date="12:42:50 on 28/06/2015" machine="Home">
    <fps_race min_fps="81.296463" max_fps="145.315414" av_fps="116.235153" min_fps_ms="12.300658" max_fps_ms="6.881582" av_fps_ms="8.603250" />
    <fps_total min_fps="81.296463" max_fps="145.315414" av_fps="116.235153" min_fps_ms="12.300658" max_fps_ms="6.881582" av_fps_ms="8.603250" />
    <results samples="21877" min_fps="81.296463" max_fps="145.315414" av_fps="116.235153" min_fps_ms="12.300658" max_fps_ms="6.881582" av_fps_ms="8.603250" battery_percentage_used="0" />
    </settings>
    </track>
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
    5960x @4.9Ghz
    4x Fury X @1125/500Mhz
    15.15
    2160P
    [​IMG]
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Matt" date="12:17:54 on 28/06/2015" machine="Home">
    <fps_race min_fps="88.537079" max_fps="181.800751" av_fps="146.049744" min_fps_ms="11.294703" max_fps_ms="5.500527" av_fps_ms="6.846982" />
    <fps_total min_fps="88.537079" max_fps="181.800751" av_fps="146.049744" min_fps_ms="11.294703" max_fps_ms="5.500527" av_fps_ms="6.846982" />
    <results samples="27492" min_fps="88.537079" max_fps="181.800751" av_fps="146.049744" min_fps_ms="11.294703" max_fps_ms="5.500527" av_fps_ms="6.846982" battery_percentage_used="0" />
    </settings>
    </track>
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
  17. savagesam117
    Mobster
    290x @ 1030/1250 (stock)
    4790k @ stock
    latest drivers, not sure what they are.
    2160p
    Need more powerrr! :( With an overclock it gave me a good 5-10fps boost but crashed at the end and i can't be bothered to run it again.
    [​IMG]
  18. Hammerark
    2x TitanX Sli @1002/1753 Stock (That's what GPU-Z says)
    i7 4790K @4.5GHz
    353.62 drivers
    @ 1080p
    [​IMG]
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Hammerark" date="22:01:57 on 30/07/2015" machine="MarksPC">
    <fps_race min_fps="124.356750" max_fps="197.160324" av_fps="157.985809" min_fps_ms="8.041381" max_fps_ms="5.072014" av_fps_ms="6.329682" />
    <fps_total min_fps="124.356750" max_fps="197.160324" av_fps="157.985809" min_fps_ms="8.041381" max_fps_ms="5.072014" av_fps_ms="6.329682" />
    <results samples="29737" min_fps="124.356750" max_fps="197.160324" av_fps="157.985809" min_fps_ms="8.041381" max_fps_ms="5.072014" av_fps_ms="6.329682" battery_percentage_used="0" />
    </settings>
    </track>
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    <resolution width="1920" height="1080" aspect="16:9" fullscreen="true" vsync="0" multisampling="8xmsaa">
    <refreshRate rate="59" />
    </resolution>
    <gamma level="0.80" />
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
    2x TitanX Sli @1002/1753 Stock (GPU-Z numbers)
    i7 4790K @4.5GHz
    353.62 drivers
    @ 3440x1440
    [​IMG]
    <benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Hammerark" date="21:51:19 on 30/07/2015" machine="MarksPC">
    <fps_race min_fps="82.844849" max_fps="116.813820" av_fps="99.728767" min_fps_ms="12.070757" max_fps_ms="8.560631" av_fps_ms="10.027197" />
    <fps_total min_fps="82.844849" max_fps="116.813820" av_fps="99.728767" min_fps_ms="12.070757" max_fps_ms="8.560631" av_fps_ms="10.027197" />
    <results samples="18771" min_fps="82.844849" max_fps="116.813820" av_fps="99.728767" min_fps_ms="12.070757" max_fps_ms="8.560631" av_fps_ms="10.027197" battery_percentage_used="0" />
    </settings>
    </track>
    <cpu>
    </cpu>
    <audio_card>
    <eq value="flat" />
    </audio_card>
    <resolution width="3440" height="1440" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
    </resolution>
    </graphics_card>
    <track lod="1.0" />
    </benchmark>
    Not sure how these scores compete, particularly the 3440x1440 one as it's not a common res. I'd like to know how it stands because I'm trying to figure out if I want to upgrade to a 5960X setup or even a 5930K to get the most out of the Titans. If anyone has any advice on that I'd love to hear from you.
  19. LtMatt
    Caporegime
    And on the scoreboard. :)
  20. FredFlint
    Wise Guy
    Run @ 1440p
    CPU = 5930K @ stock
    GPU = Fury X @ stock
    Windows 10 Driver =15.20-150715a-184226E
    [​IMG]
