Do you guys use DSR with your games on a 1080 screen?
23 Mar 2011
Just found this feature now that i have a 970, so am i right in thinking it lets you run at higher resolutions on lower res screens? so 1440p on a 1080p monitor for example?
i imagine it makes it sharper, just dabbling with it now! do you guys use it? i imagine its good for older games to still maintain 60 +fps but on newer stuff there would be a big performance hit?
Essentially, yes. It downscales a higher resolution to give a sharper look, removing (some of) the need for anti-aliasing. It works well, and I've found so far that DSR will perform better than say using 8x MSAA, and doesn't have the blurred effect that FXAA and TXAA bring.
Yes I tried mafia II @ 5K still ran smooth as and was a huge improvement in IQ
But I wouldn't recommend it on latest games as its just like running at the set dsr resolution.
i tried it in pillars of eternity but dont think it works well with that one, however it seeme to work if i changed desktop res aswell but the text then had a bit of blur to it.
Text quality will always be compromised to some level - lesser so when using exact multipliers of the native resolution.
I find it works best with older games though where in some cases it can make them look a lot nicer - some newer ones the performance hit is a bit high.
Overall its a very useful tool to have to hand but I don't run it indiscriminately.
just had a little play in CS:GO, can pop that up really high and maintain really high fps. dont really notice it until you look at it side by side (i took a few shots both 1080p, and higher) much sharper textures etc :) nice feature
Shouldnt have dabbled into this.. Now i want a new monitor as i think the 970 can handle games fairly well above 1080! Off to the monitor section i go :)
Just use conventional resolution Downsampling with Nvidia Control Panel.
Google for guides.
Eg: http://neogaf.com/showthread.php?t=509076
Thats great if you want it just for the super sampling/AA side of it but DSR goes a bit beyond that not just to use the extra detail to improve edge quality but to also (via semi-intelligent filtering) try and preserve as much detail from the higher resolution as possible in the down sampled result - also increasing the perceived intra texture detail as well as edge filtering. (Most down sampling systems will use an undiscriminating interpolation mechanism which usually just averages the results sometimes with some basic weighting).
Yeah I have the 980 and I am thinking about 1440, you should be able to max games at that res tbh without much hassle.
I have no problems with a 780 clocked to stock 980 performance on the Swift (2560x1440).
Nice, how is 1440 compared to 1080? Is it worth a £300-£350 upgrade. I think you can get 27" screens for that, either that or a 32" at 1080. Not sure what to do tbh.
TBH for FPS games online, etc. I'm not really fussed but it is nice to have the extra resolution for single player, MMOs, etc. can't really comment on the value for money side as it wasn't a purchase I had second thoughts over, etc. I wanted it and had the money so did it.
Ah I see :) Yeah I have to be a bit careful I just spent just over 550 on the 980 and a new PSU. If I want to spend another 300+ I really need to justify it to the wife because as far as she is concerned she does not understand why it costs so much. She just see's the adverts for consoles that cost £300 and you are done for 10 years or however long they last these days.
I'm finding my 980 copes pretty well at 1440, although you will still have to turn certain settings down in some games if you want to maintain that magical 60fps. I couldn't imagine having to go back down to peasant 1080/1200p resolution nowadays :p
true that :D
so to confirm, this is pretty much running the games at these resolutions, so if i go for a 1440p monitor, i can expect the same performance that im getting using DSR at 1440p on my 1080p screen? no trickery involved? :P
really impressed with the 970, but its made me want this new screen :) been recommended a 25" dell one over in the monitor section so may just go for it :D
DSR basically works by rendering the scene as if you had a higher resolution monitor i.e. 2560x1440 if you use that level of scaling with DSR then using that information to try and rebuild the image at your native resolution as closely as possible using semi intelligent filtering - so theoretically you should see slightly higher performance if you were rendering 2560x1440 natively though the filters used by DSR have fairly low performance impact.
Which is why if you screenshot a game with DSR active you get a huge image which is the original image as rendered by the game before any DSR processing is applied instead of a screenshot at your native resolution.
