*** League of Legends ***
I suspect you will find Riot can see a drop off of people using it akin to falling off a cliff and hence why these modes never stay.
For the record Aram I enjoy as a wind down, SR I like and I want to like 3v3 but am not versatile enough on the champs :(
It's an issue I think between BT and Riot, I disconnected the modem and reconnected and that seemed to resolve it - others indicate keep trying and you get in but my reconnect seemed to do the trick :)
Just started out playing this.
Is it good to get used to a bunch of characters or keep to same one? I seem to be half decent with voluntary.
Also what level can you jump into ranked game's?
Level 30 for ranked - and even by then you may find it a struggle. The best idea is to try each of the free champs each week (rotated on Tuesday) and when you find one you particularly like / are good with, stick with it and learn it off by heart. And ideally need to pick up couple of champs to that standard in a couple of positions (top, mid, Jung, adc, or supp) in time for when hit ranked
done these promos 4 times now but still feels good every time :p
in regards to the bunch of champions, I found that playing every single champion to the point where I knew their abilities was a huge benefit. Knowing your enemy helps way more than you'd think.
I find it trying learning other champions, mostly because I utterly suck and want to be instantly competent as I am with my mains. But the above is very true.
I need a few guys and gals to play with ...don't have to be good as i'm a noob myself but i'm going insane with randoms and lack of awareness and not playing as a team/no comms.
youre not alone! I think hes the hardest to get used to out of the lot. aa and axe management is too hard in teamfights
And he's really crap at kiting, if you're running backwards your axes land between you and whoevers chasing you :mad:
And there's the problem of your axes landing next to their tank or in range of their Zed etc. :D
2.5K crits are no joke though
Assuming you are level 20+ The mumble group seems to have got really quiet lately so hop on in - details on the first post of this thread.
Suggest you also join the ocuk channel.
Goes for anyone in this thread - very dry spell at the moment for people being around :(
Cheers i can level up to 20 and jump on one night.
whats with the new scoring system? Good indication of how good you are or just there to add to all the other numbers and stats :P
Seem to be getting a's and b's er game so cant be as bad as i thought.
He's actually really good at kiting, you can control which region his axes will land, for example, if you auto attack then right click forward your axes will land in front of you or if you right click backwards they go behind you, same for left and right, pretty hard to master, definetly my favourite ADC to play.
