I know it's been said before but I'm sure this is you..
Yeah thats Kaap alright
if this is right, then what i was say in the other thread is right, the 390x won't be near / on pair with a 295x2 or even a TX, just look at the specs of the 390x vs 295x2
All speculation at this point. You could be right, but then HBM could make a bigger difference than we think. We shall find out in the next 4 weeks![]()
but the memory bandwidth on the 390x is the same as on 295x2
http://www.game-debate.com/gpu/inde...101&compare=radeon-r9-390x-vs-radeon-r9-295x2
I wouldn't put to much stock in that. More to it than that.
The 295X2 = 1024Bit
The 390X = 4096Bit
The 295X2 = 1024Bit
The 390X = 4096Bit
Don't put too much stock into the maximum theoretical bandwidth but go by the bits instead? seriously?
I think what you meant to say is that 295X2 is two 290X's built upon a single PCB, each GPU has the same 320GB/s bandwidth as a single 290X. You can't just double things up like that website has Crossfire doesn't work like that, 295X2 can only be directly compared to a future 395X2(?) or two 390X's in Crossfire if you're going to do it that way.
i know mate. but either way HBM will only help in very high resolutions etc scenarios
Going by number of shaders on 290X vs number of shaders for 390X... I would expect performance to be 5-15% slower than Titan X depending on game![]()
I'm not sure we really want the 390X to have the same performance as Titan X or more.
i do hope 390X is a 5-10% slower than TitanX and 390 is around 980 level.
what i do really hope is price wars. If 390X is better than Titan X all is nice and toasty but that will enable AMD to charge "an arm and a leg" for it.
I'd prefer it being slower, but at a interesting price.
For sure but not unrealistic.Paper based stats tho lol
