First engineering samples are starting to leak out!
Pretty useless until we know the cooling and voltage used, also bear in mind the 5775C has only 6MB of cache.
I7 5775C clocked to 5.0Ghz... Remember when Boomstick (Moi) said all hope was not lost
All hope is still lost, since this wasn't stable even with 1.419V (suicide run) on air. All he was able to do was take a screenshot before it crashed.
Seems very similar to the 4790k overclocking, at least overclocking hasn't deteriorated even further from the 22nm node.
All that's left to see is how the 128MB of eDRAM will affect things, though remember these only have 6MB of L3 cache, so I suspect it will balance out the performance.
I'm much more interested in Skylake at this point, since we get the vastly improved Z170 chipset, with much greater PCI-E lanes for SSD's.
I never believe OCing results until real-world reports can be collated from dozens of forumites.
Disagree, these chips look like an alternative to 4770K / 4790K without having to switch mobo or buy DDR4 like you do with Skylake.
If they can reach 4.8Ghz > 5.0Ghz on air they def have potential, especially if they run cooler.
For everyone else who's going to be using a dedicated GPU, 4790k or Skylake or X99 is a much better choice.
How you can say that without seeing the performance? You keep making blanket statements based on thoughts not facts
We need to see legit benchmarks / reviews before condemning Broadwell![]()
We've already seen it's SuperPI scores (from the facebook leak) which are unimpressive, since this CPU is clocked way slower than a 4790k and has 2MB less L3 cache.
Once again, these two Broadwell-C CPU's are not meant to be successors to the 4790k. They are successors to the 4770R (Iris Pro Haswell). Skylake 6700k is the true successor the the 4790k.
