Multirotor, multicopter and quadcopter discussion - The Drone thread
I dunno, I would not fly a £1800 UAV in a hall stacked with all those lights dangling down... but hey that's just me and I'm poor lol
Anyone seen those 5.8Ghz cloverleaf antenna's someone linked before? I cant find any of the decent ones on ebay (the were metal coax cloverleaf, had a black stem)
Apparently outperformed most of the £15 cloverlead ones on the bay
However no where to be seen... Im going to need a converter too, as my fatshark goggles has one type of connector, and my vtx has another
Or will these do?
http://www.ebay.co.uk/itm/Fat-Shark...054?pt=LH_DefaultDomain_3&hash=item51a8e61d56
Apprently the ones I want are made by someone called gav.
Just done a 6 mile trip on my phantom 3 proffesional. had problems with gimbal and had lines going into image when was flying downwind. coming back lines had gone. come home calibrated gimbal and picture is loads better.
linky.
still had full rc signal and full video signal, range on these is amazing. recorded in 4k.
linky.
Verified phatom owner flying over railway lines, houses and roads. Good job
chance to fly after work today with the nicer weather. Gimbal is now controlled by a 3 way switch. Need to tweak the settings when the gimbal is rotated 90deg down. Bit gittery.
I think you might need to balance your props/motors dude. Video looks like the gopro was mounted to a bunch of fat birds trampolining on pogo sticks around in a mattress factory :D
Good work otherwise!
lol. Nice description :p
I've got some softer isolating rubber grommets i might try. The ones that came with the gimbal are pretty solid which isnt helping me thinks. Reduced a fair amount of the jelly effect by fitting an ND8 neutral density filter. Other videos shot in sunshine were pretty bad in places.
I'm learning more & more along with emptying the wallet quicker and i thought archery and photography were money pits ;)
I think I am going to swap back to my white DJI legs, think it flies much better, and make something like you made above
Only problem is the landing on white legs is a little more tricky in FPV, would either have to be very gentle otherwise it topples over, or hover and land LOS.
It's cheaper to balance your props and motors! There's a couple of good vids on youtube that show how to dynamically balance motors. You just need a vibration sensing app for your smartphone.
Basic theory is;
  • Props off
  • Put phone on top of craft
  • Spin up one motor at a time, clock vibes on phone
  • Make a mark on the motor with a sharpie or something
  • use a piece of VERY sticky tape or a small cable tie around the motor
  • Spin up motor again
  • <vibes that's the side of motor that needs weighting
  • >vibes it's the other side that need weighting
  • Keep moving the tape/cable tie around until you're at the point of least vibes
  • Mark again so you don't lose the spot
  • Then it's just a case of adding some epoxy inside the motor to permanently
    weight it at the right place.
Balance your props first though, it's a lot easier and quicker!
Generally, I don't tend to bother too much as the smaller motors and props don't seem to be too bad.
Terrible day yesterday. Batteries all charged up for lunchtime sunny flying and our sodding accountant came in for a day long meeting. Bah.
And then the blimmin g/f wanted to go and spend the whole evening sat in a pub beer garden for some reason!
Still, there's always the weekend I guess :)
Basic theory is;
  • Props off
Cheers for that. Something to keep me busy over the weekend.
Not a straightforward job balancing the props as they are self tightening. But found someone selling a CW/CCW threaded balance rod. Mucho cheap too.
For anyone who has that fpv sim, its had an update apprently,
im going to re-try it on the weekend
There has been an improvement and upgrade to the sim here http ://fpv-freerider.itch.io/fpv-freerider if you allredy have the full version its a full its a free upgrade,Marty and the borrowed doggie
