I'd had my CB1000R a month when I crashed it on Brands Hatch. I got most of it fixed, but the fuel tank looked to be over a grand to have it sorted, so I just put a baglux over it.
A month or so back I found one on eBay for £280, had it fitted yesterday when having the spark plugs changed and after 3 years, it's once again looking like it's supposed to!
stick the tank cover back on now and protect it
my new rubber arrived this morning
House mate laughed at me the other day when I told her how much my Halfords socket set cost, until I explained that I've saved that a couple of times over already on garage labor charges.
It's also really weird with a new clutch cable, feels so much lighter and nicer then again the old one was in a rather **** state when I took it off after it snapped.
if you can get a trade card you'll laugh at how much they cost lol, most tools are about 50% off or more with a trade card
I found that the clutch cable adjusters are the cause of snapped cables most the time,they chafe on the cut out slot where you slot in the cable
I learnt how scarily easy it is to start a motorcycle with nothing more than a piece of wire and your teeth..
