Will they have HDMI 2.0 ?
For Nvidia that all-in margin figure is 11.64%, it was around 15% in 2011.
You can't really use that figure in the context of this question because it has all sorts of deductions in there and it can also be negatively manipulated by in-efficiencies in the company as much as R&D. Gross margin is the best per product figure to use in order to determine how much money a company generates off a given product.
To get an understanding of per card profit vs. R&D cost you need to look at in a per quarterly fashion. Nvidia spends around $1.3BN USD per year on R&D investment against $4.7BN USD revenue.
Roughly 25% ? so on a gross margin per Titan X card ($400 approx. profit) that means that inside the $400 USD Nvidia spend $90 USD on R&D.
So, minus R&D costs you could then speculate that Nvidia make $390 USD on each Titan X card, assuming my earlier example of a $1000 USD inc. retail price.
There is not even any decent rumours here for my "Rumour Mill Thread" here.![]()
Obviously nvidia is not getting the entire pie! from those 1000$ lets say 18% goes to the etailer, another 15-20% to the brand (AIB)...taxes ... and then leaves nvidia with unit price of around 500-600USD.
Found out yesterday my computer struggled for the first time gaming. I had to drop the res in Mortal Kombat X. Do we know what the pricing for these cards are yet? or is it better to get a 970/780ti/980?
Did anyone know that GDDR5 does not require equal trace lengths?
https://www.micron.com/~/media/docu...note/dram/tned01_gddr5_sgram_introduction.pdf
Not Fiji related I suppose but doesn't deserve its own thread and curious if this is common knowledge.
Interesting stuff (theory) about why fiji won't be a giant chip.
http://forums.anandtech.com/showpost.php?p=37407110&postcount=480
Makes way way too many assumptions. Either way 550mm^2 compared to 600mm^2 isn't a huge difference and is still absolutely a huge chip.
One of the reasons Hawaii was so good in terms of die size/performance over the 7970 is because the process matured significantly from almost the first products out on it like the 7970 to a significant time later with the 290x. There is only so much saving you get from process maturing. For a new chip on a lower yielding new process you make conservative designs, leaving a little more space(talking another 2-3nm) and maybe throwing in a little more redundancy.
Refreshes of products within a process are usually 5-15% more dense precisely for those reasons, but that is effectively a one time shot, you can't take that 5-15% extra space you left out of the first product for yield reasons more than once.
In terms of the memory controller, there are lots of rumblings, about an HBM memory controller being much more simple and thus smaller... but then it's massively wider. 4096bit vs 512bit is not insignificant. However producing signals that are a magnitude smaller means a lot less logic/components there as well. it's questionable at this point how a 4096bit HBM memory controller will stack up vs a 512bit gddr5 memory controller in size.
Only god knows.
