No, but I would generally be wary of any program
a) that's charging you a lot to even see it and promises x/y/z
b) is made by an IFBB Pro - volume tolerance is much, much higher for someone on gear and also they can do more elaborate split routines and still make progress due to muscle protein synthesis being elevated for way longer. Those on j00ce are notoriously bad at coaching those who aren't, and I'd expect the same would apply when it comes to writing up routines for the masses.
Depending on your goals/schedule you could look at ones like these (which are mostly templates/ideas rather than fixed routines)
Lyle McDonald's Generic Bulking Routine
Cody Lefever's GZCL (can be done as upper/lower, PPL, whatever)
Some variation of 5/3/1
Brad Schoenfeld's Max Muscle Plan
As said, depends on what you're trying to achieve with your training as obviously although they all centre around progressive overload, the ones aimed at improving your 1RM/powerlift-y type stuff are quite different to the ones geared towards bodybuilding/more moderate and higher rep stuff, aesthetics etc.
