Is that an official bit of artwork from AMD?
Mal X
Could you try something with your 12gb TitanX and 2160p TV
Load up a copy of The Witcher 3
Max the settings out @2160p
See if you can get playable fps, extremely unlikely
Check the VRAM usage and you will find it is only using 3gb.
All cards/setups are a balance between memory and GPU grunt. There is no point having 12gb if you don't have the grunt to use it.
Not without some drivers/profiles it wont!
Its from Powercolor.
Where is this from?
maybe when it's struggling at 4K, it's using far less RAM than at 1080p and 120 fps............ not sure
but to me it makes sense that it'll only use a massive amount of RAM if you unchain it and let it run free, which means the same Pedigree of card but in two years time............``Titan Terminator``![]()
but i still wouldn't buy a 390X at 4gb..i wouldn't go near it, because it simply feels wrong
In the picture I quoted.
You see that bar thats slowly climbing into the red?
Worrying.
Or do you mean where is the picture from?
Where did that image come from, to me it looks like a photoshop fake and not a very good one at that.
I don't know, I just saw it and quoted it saying it looks like a thermometer going into the red.
And the GFX forum loses their mind.
Maybe I touched a nerve![]()
It does not bother me.
If people look closely it is a 295X2 with the thermal bar placed on top.
Nothing to get excited about at all.![]()
Mal X
And "in THE world".Its annoying me no end that it doesn't say 'graphics' on there![]()
OopsAnd missing "The" is winding me up.
4GB IS NOT CONFIRMED, HE SAID NO COMMENT BECAUSE IT'S STILL UNRELEASED, THAT IS ALL
EUROGAMER ARE JUST SPEWING.
Joe Macri did close our discussion mentioning that while what we see here with Gen I HBM is shown with four stacks of DRAM, it could possibly go higher as production methods of HBM became more precise, but they simply did not know yet. Gen II HBM is targeting eight physical stacks with possibilities as high as sixteen stacks.
This is mentioned in the hardocp article:
Still a possibility of 4 gig i suppose, but as a new tech it has to start somewhere.
