I don't see the issue with crossfire support for freesync as SLI with gsync has stuttering issues and most people are only using 1 of their GPUs because of this so I don't blame AMD for holding back the freesync crossfire support if that is going to have the exact same problem as SLI and gsync, it will just annoy even more crossfire users.
Are they now? I use GSync with SLI and it's smooth as butter. 1440p144 means you really want/need freesync or gsync. Lack of crossfire freesync support is a big deal.
Freesync also has quite limiting refresh rate ranges, and doesn't work with some quite recent GPUs (here's looking at R9 280x. I would have had to replace my 7970/7990 trifire system anyway to use freesync, so was just as well going gsync.)
