Caporegime
- 30 Jul 2013
1.281v is fine for liquid/water.
Think you need to flash a bios to get it that high though.
So 119mv on MSI afterburner?
Well I think my Titan X might be broken.
It now locks up straight away under any kind of load as soon as the scene loads, whether it's a game or benchmark.
Edit: It seems the card is boosting itself to silly clocks and voltage on its own.
Core clock and voltage shown were in GPU-Z render test.
I've uninstalled any overclocking software but it's still doing it.
I had the same with maxair bios, swapped it back to EVGA SC and all is good.
It tried to load max boost as soon as put under load. Instant freeze for me. But mileage can vary, mine is on air and ASIC only of 65%.Good to know, does the bios get stuck or something and just try to load the max boost and voltage it can under load?
I'm on air as well around the same ASIC %.
I'm going to wait till the EVGA Hybrid cooler is out for the TX before trying a bios with higher voltage again. The SC425 bios will do for now.
Question for anyone else - is there an intermittent audio stutter in each of these videos? Everything else playing fine via YT, but these stutter pretty bad.
ZOTAC announces GeForce GTX TITAN X with Arctic Storm cooling
http://videocardz.com/55725/zotac-announces-geforce-gtx-titan-x-with-arctic-storm-cooling
After an honest answer, just how loud are these cards when gaming?
I've only ever had 1 reference cooler which was on a sapphire 290 & it was the noisiest thing I've ever used.
I know you can mess around with custom fan profiles, but in general what are they really like.
I've currently got 2x Gigabyte G1 970s which are fairly quiet when gaming, fans probably hit 60% & Temps around 65-70c after a couple of hours.
Honest answer, after having aftermarket coolers, single and in sli, this one is too loud for me. To keep it around 70C you have to put fan on 70%, which is loud. Fortunately we have option to swap reference cooler for EVGA AIO or ACX2. It costs extra on top of £900 though![]()
I keep mine at 60-65% to keep it below 80 degrees. It is loud but not distractingly so (when you're in game you won't hear it). Although that's subjective.
Is anyone planning to buy the ACX 2.0 Cooler? It's avaialble now on the EVGA EU site. I'm personally waiting for the Hydro Copper though. Since I really want to avoid SLI, being able to clock to 1500+ from 1350 on air should result in a substantial performance boost.
