Caporegime
- 18 Oct 2002
Price is a bit wrong but a gorgeous case!!!
The Fractal Define S has this buried for value!!!!
Do want!!!I suggest that you make a pre-order now to secure stock as we have obtained the very first stock off the production line
The concepts show it with the window and 'front' IO on opposite sides? I don't understand why anyone would design a case with the IO on the opposite side to the window...
You can either get to the IO and not look through the window, or you can look through the window and not get to the IO. You also can't have it against a wall either way, you can't put it under your desk with the window facing you, etc.
Completely stupid.
Please tell me they have changed that and put the IO on the front or the top?
IO on the ATX case is on the front, you can see the plate at the top that opens to reveal the IO.
Well the Evolv will have max 360 front and top where as the Define S you'll be able to have a 420 in the top however (A thickness limitation of 55mm for both radiator + fan applies on 420, 280 and 140 mm radiators).
Not a huge difference cooling wise, I guess it'll be down to which layout suits you best.
No immediate plans for a white one. And anyone complaining about the price remember it's got a 3mm Aluminium external chassis, which isn't cheap. Links will be live about 10am!
Nice one, which model did you go for? Already lots of preorders guys, and first stock is limited!
I went for Gunmetal Chug, I have a some ideas but need to speak to some people.
Wonder if Phanteks supply spare front panels, might have to modify mine also !! Would hate to mess it up![]()
