Do people think the initial high end pascal will be much faster than Titan X?
Def worth going for a Hybrid. If there had been a TX Hybrid at launch I would have gone for that for sure.
These GM200's are hot chips and would love some water.
The Nvidia CEO said the next high end series would be Pascal on 14nm next year. Probably Q2/Q3 2016 time-frame for the different models. Expect full chip (Expensive) early etc (March) and then roll out the full series over the year.
I still think we will see a GTX 960 Ti 3GB 192/Bit/Bus this year but no more higher end cards.
I wonder how 2x GTX 980Ti's will stack up against 3x GTX 970's ?
No doubt 2 980Tis will be faster than tri SLI 970s. One 980Ti with a 1400MHz+ OC is already better than 970 SLI and more than two card SLI shows diminishing returns in extra performance. Especially when the 970 is held back by a much weaker memory system than the 980Ti.
Which review shows that a OC 980ti is better than 970 SLI? That's awesome if true
Also would the EVGA GeForce GTX 980Ti Superclocked ACX 2.0 overclock a lot more than a EVGA GeForce GTX 980Ti "Reference Design"?
I'm hoping the Reference design can achieve 1400MHz if it's able to match 970 SLI
The 1400MHz GPU speed on OC'ed 980Ti's is the maximum boost clock and not the overclocked base clock. Base clock is 1000MHz and OC'ing it to 1200-1250Mhz should give you a boost clock of around 1400MH.
As for the 980Ti vs 970 SLi i found this review - just scroll to the 2nd section with single 980Ti vs 980/970SLi. You see the 980Ti is darn close to 970SLi and that's with stock clocks.
http://www.maximumpc.com/nvidia-geforce-gtx-980-ti-review/
I'm hoping this is out soon
And can turn the cheaper cards into an evga hybrid for cheaper!!
It's confirmed working for the 980ti and Titan x
The hydro cooler is already able to be purchased from evga at just over £100, the corsair route will be around £29.99 (same as n780) plus £50 for h55 (can be found cheaper too) so it's approx £20 cheaper than the built in version or buying the hybrid separately.
The other advantage of the corsair one is you could always drop a h100 or 280mm AIO on it for even better performance
This is soooo not fair. I've just checked the Anand Tech:
http://www.anandtech.com/bench/product/1446?vs=1496
Makes me want one![]()
That can't be right can it?
So tempted to sell my 980s for 980tis
